    Mar 2011
    Oregon, US
    Im trying to figure out why I get this on my screen when I try to play it on vlc 3.05:Click image for larger version
ID:	47639. Then when I played it on Movies and TV , I get a perfect picture:Click image for larger version
ID:	47640, Can I get it to play on VLC so I can get a perfect picture like movies and tv? also can someone tell me if I will get a picture or just lines on WDTV LIve? thank you for your help, here is the mediainfo:
    General
    Unique ID : 156726307447661154980894159630167172617 (0x75E8638C3DE27F5F16A41A277CABE609)
    Complete name : O:\Hogans Heros\Season 1\title_t00.mkv
    Format : Matroska
    Format version : Version 2
    File size : 1 003 MiB
    Duration : 26 min 38 s
    Overall bit rate : 5 260 kb/s
    Encoded date : UTC 2018-12-27 22:29:09
    Writing application : MakeMKV v1.14.2 win(x64-release)
    Writing library : libmakemkv v1.14.2 (1.3.5/1.4.7) win(x64-release)
    Video
    ID in the original source medium : 224 (0xE0)
    Format : MPEG Video
    Format profile : Main@Main
    Format settings : CustomMatrix / BVOP
    Format settings, BVOP : Yes
    Format settings, Matrix : Custom
    Format settings, GOP : M=3, N=12
    Codec ID : V_MPEG2
    Codec ID/Info : MPEG 1 or 2 Video
    Bit rate mode : Variable
    Bit rate : 5 064 kb/s
    Maximum bit rate : 9 002 kb/s
    Width : 720 pixels
    Height : 480 pixels
    Display aspect ratio : 4:3
    Frame rate mode : Variable
    Frame rate : 23.976 (23976/1000) FPS
    Original frame rate : 29.970 (30000/1001) FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.611
    Time code of first frame : 00:59:59;00
    Time code source : Group of pictures header
    GOP, Open/Closed : Open
    GOP, Open/Closed of first frame : Closed
    Stream size : 965 MiB (96%)
    Language : English
    Default : No
    Forced : No
    Original source medium : DVD-Video
    Audio
    ID in the original source medium : 189 (0xBD)128 (0x80)
    Format : AC-3
    Format/Info : Audio Coding 3
    Commercial name : Dolby Digital
    Codec ID : A_AC3
    Duration : 26 min 36 s
    Bit rate mode : Constant
    Bit rate : 192 kb/s
    Channel(s) : 2 channels
    Channel layout : L R
    Sampling rate : 48.0 kHz
    Frame rate : 31.250 FPS (1536 SPF)
    Bit depth : 16 bits
    Stream size : 36.5 MiB (4%)
    Title : Stereo
    Language : English
    Service kind : Complete Main
    Default : Yes
    Forced : No
    Thank you all you fine outstanding in your field people! John
  2. Do you have a link to the website from where you downloaded the video?
    VLC has no problem playing MPEG2 video an AC3 audio. So you probably didn't download it correctly.
    Mar 2011
    Oregon, US
    I didnt download it , I ripped it from the dvd!
  4. Originally Posted by RBCC View Post
    I don't see any reason why VLC wouldn't play it then. Unless it wasn't decrypted properly. Can any other player play the video?
    Mar 2011
    Oregon, US
    yes movies and tv off of windows 10
  6. Member DB83's Avatar
    Jul 2007
    ^^ Not exactly the answer that jagabo is requiring. Better re-read the question.
    But I have read on here before that Makemkv is known to do some screwy things to frame-rate. And the mediainfo report, if it is to be believed, stated that the original 29.97 fps has now changed to a variable 23.976 one. I know that Hogan's Heroes is quite old but would that have been shot on film ?
    I would suggest using a different ripper. One that retains all the original features e.g frame-rate. If you still want a mkv container then mux it after the rip and not as part of it.
  7. Originally Posted by DB83 View Post
    Most likely.
    https://www.imdb.com/title/tt0058812/technical?ref_=tt_dt_spec
    One odd thing I noticed about the video though:
    Maybe VLC is getting confused by that? Do other files from MakeMKV (?) show similar starting time codes? Do they play properly in VLC?
    Some things to try:
    Remux the video with MKVToolnix. Does the new file play properly in VLC?
    Demux the audio and video into elementary streams. Do the elementary streams play properly in VLC? Mux the elementary into an MKV. Does that new MKV file play properly?
