Hi, I'm a total new just started working in a company asking me to create videos I have no knowledge off and I'm the only designer working here, so hope you can help.
I was instructed to create a video for a digital billboard the size of 39m x 9m. My question is to make the video I have to follow the dimension of the billboard right for it to play properly once it projected. Or I can create a much smaller size not following the original billboard dimension but a scaled down dimension but as long the output of the video is HD or 1080p. I hope you can help me with this, I searched the internet and didn't find answers that completely answer my question. All the help would be appreciated Thank you.
I'm using adobe premiere pro CC to create this video.
	Did they order fries to go with that?
 Relax, I've done this many times.
 None of that are my shots, but this is what they are looking for. You don't need to go all the way, so you don't need to encode a 39m x 9m video, you can do a 3900x900 and let the projector upscale that, but at first, you have to know what is the equipment you are gonna deal with.
 Take a look at this:
 The software and projection are gonna use split screens? They can handle a full projection? What is the software they are gonna use for playback?
 Another thing to take in to consideration is the public distance, the farder away the projection is people will not be able to see details, but the close it gets you have to take a good care of resolution and bitrate.
 My suggestion to you is to calm down, go see the projection site, the equipment, do some tests, you don't need to develop a video at first, make a sample image with photos and some tests, see if the projector accept the resolution you are using and you go from there.
	Most important is pixel aspect ratio and display aspect ratio (in your case 39:9)- if you have those values and additionally you have accepted resolution then rest should be straightforward.
  I need help on creating a video based on route mapBy vbas28 in forum Newbie / General discussionsReplies: 2Last Post: 15th Aug 2018, 11:23
  Creating a video with certain specsBy Run222 in forum MacReplies: 7Last Post: 21st Mar 2018, 19:04
  creating watermark for video???By kenny1999 in forum Newbie / General discussionsReplies: 5Last Post: 1st Jun 2017, 18:08
  Creating Octagonal M4a to embed into a videoBy jakejeffery in forum AudioReplies: 3Last Post: 27th Oct 2015, 20:21
  creating info from a video fileBy JackieOne in forum Newbie / General discussionsReplies: 3Last Post: 7th Dec 2014, 09:30
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
