Hello. I've tried using VSDC to edit down some of my mp4 files. Once i've finished cutting, i set MP4 as the output file and export it. However, each time i try, the completed video is put into slow motion despite me not wanting it to. Is there anything i can change to make the end file the same speed as the unedited original clip? Thank you.
Have you tried using other editing software? I've found that LosslessCut works pretty well for simple cuts.
It's free.
You just have to make sure not to cut in the middle of a frame (which produces a corrupted frame).
VSDC basic editing concept
By jotti in forum Newbie / General discussionsReplies: 5Last Post: 16th May 2019, 07:14 -
VSDC Editing Woes (Resampling)
By alienencounters in forum EditingReplies: 1Last Post: 3rd Aug 2018, 22:36 -
Editing VSDC sprites
By wilder in forum EditingReplies: 0Last Post: 16th Jun 2017, 14:38 -
VSDC Editing help
By Irfaankahan in forum EditingReplies: 2Last Post: 7th Apr 2016, 04:04 -
VSDC - File not found
By yellowfin in forum EditingReplies: 4Last Post: 27th Feb 2014, 20:51
