How to make a .mp4 file into DVD Playable Format?
Please suggest which tool can do that faster?
Sent from my LG-M700 using Tapatalk
Results 1 to 24 of 24
You must be doing something wrong, this is the most recommended DVD creation software package in these forums
I'm not creating a DVD I'm asking for convert mp4 into vob or mpg or another format that is Playable for DVD player.
Sent from my LG-M700 using Tapatalk -
I'm certain AVStoDVD can convert from H.264 mp4 to mpg. The mpg file will contain DVD-compatible video and audio, but most DVD players can only play authored DVD (IFO, BUP, and VOB files). A smaller percentage of DVD players also play xvid or divx files. Some Blu-ray players can play mpg files. I haven't seem a DVD player that plays mpg files.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Okay thanks for this helpful information
And one more thing my mp4 video is 679 MB
There's video bitrate is 68 kbps
Audio bitrate 126 kbps
Resolution 320x240
Duration 7:17:35 Something
So how to make DVD Playable Format in same size like 679 MB to maximum 690 or 700 MB
Sent from my LG-M700 using TapatalkLast edited by imsrk48; 26th Dec 2018 at 22:38. Reason: Some text missing
You should probably make it 352x240 and you should probably fill the whole DVD-5 disk. It looks like crap already. By limiting the size it will look much worse.
Nothing I'm serious maybe not any software available that can encode 68 kbps video bitrate so now ignore this i want to stop this topic I'm very tired with finding solution about this.
I'm thinking to directly burn my video into DVD disc because it's very though to make in DVD Format faster for play via pendrive.
Assuming for the moment that you are serious, then your expectations are unrealistic. MPEG-1 and MPEG-2 video are the only types allowed for authored DVD video. Both MPEG-1 compression and MPEG-2 compression are much less efficient than H.264 or H.265.
Even at 352 x 240 (the smallest resolution allowed for DVD), 7+ hours of MPEG-2 video would require much more than 690 or 700 MB to be watchable, assuming it contains a moving picture with some amount of detail. Also, DVD video is interlaced. As manono said, even if you fill the entire DVD to capacity (4.37 GiB), a 7+ hour video is going to be ugly to watch.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
At 68kbps it probably already IS ugly to watch, unless it's still pictures/slideshow.
Scott -
https://m.youtube.com/watch?v=tlK2uQlTeuY
Here is link check it's highest resolution -
If you want a better, more accurate, opinion of the quality and what might be possible,
post some of the original file. Youtube has re-encoded your file upload, it's useless
as a sample -
If your mp4 is a download from that exact Youtube video, then it is poor quality for 2018. It reminds me of a VHS tape recorded in SLP or EP mode. A DVD video version won't be as "good".
The only digital video that I have watched which was comparable was my nephew's college commencement ceremony, streamed by the university in low resolution, low bitrate, compression artifact-riddled wmv. It was painful to watch. The DVD video version that I created for his grandmothers was even uglier than the original.Last edited by usually_quiet; 28th Dec 2018 at 09:17. Reason: grammar
Format factory V4.0.0.0 not converting DVD video to mp4
By thewildgoose in forum Video ConversionReplies: 2Last Post: 15th Dec 2016, 01:36 -
playable .ts format
By advan in forum Video ConversionReplies: 9Last Post: 21st Apr 2016, 01:11 -
Using mp4box -splitx to crop mp4 creates playable file w/o height, width
By myDorazio in forum Video ConversionReplies: 5Last Post: 20th Apr 2016, 16:20 -
need help converting MP4 to DVD player compatible format!
By nite_hawk in forum Newbie / General discussionsReplies: 9Last Post: 8th Mar 2016, 04:03 -
Homemade mp4 files quality vs. ripped movies in mp4 format
By MrMX in forum Newbie / General discussionsReplies: 11Last Post: 26th Nov 2015, 22:12
