Results 1 to 30 of 49
  1. Hi, please be patient I'm a c*t
    some days ago I buy a new laptop, this :
    CLEVO P775TM1-G Desktop Laptop
    Processor:
    Intel Core i7-9700K Unlocked | 3.60~4,90GHz | 12MB | 8C/8T | TDP 95W | Coffee Lake R
    Display:
    17,3" Full HD 1920x1080 IPS 60Hz Matte G-Sync | 72% NTSC
    Graphics Card:
    NVIDIA GeForce GTX 1060 6GB GDDR5 | OC Edition | VR-Ready | MXM
    Thermal Compound:
    Repasting CPU | GPU with IC Diamond 24
    Memory RAM DDR4 SO-DiMM:
    16GB ( 1x 16GB ) DDR4 2666MHz G.Skill RipJaws | Kingston HyperX
    Primary HD for windows: 2TB Seagate FireCuda SSHD 2,5" SATA | 5400rpm | 128MB Cache | 7mm
    Secondary for video: 2TB Samsung 860 Evo SSD 2,5" SATA | R/W 550/520 MB/s | 7mm
    I have try to encode some video files but I noted that econdig speed is too slow:
    FFMPEG2018.exe -y -threads 16 -i concat.mov -pix_fmt yuv422p -c:v libx264 -profile:v high422 -level:v 4.1 -g 33 -bf 2 -crf 19 -flags +ildct+ilme -top 1 -c:a ac3 -b:a 320k -ar 48000 -aspect 16:9 test.mp4
    ffmpeg version N-91127-g411f7141a3 Copyright (c) 2000-2018 the FFmpeg developers
      built with gcc 7.3.0 (GCC)
      configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-bzlib --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvorbis --enable-libvo-amrwbenc --enable-libmysofa --enable-libspeex --enable-libxvid --enable-libaom --enable-libmfx --enable-amf --enable-ffnvcodec --enable-cuvid --enable-d3d11va --enable-nvenc --enable-nvdec --enable-dxva2 --enable-avisynth
      libavutil      56. 18.102 / 56. 18.102
      libavcodec     58. 19.102 / 58. 19.102
      libavformat    58. 15.100 / 58. 15.100
      libavdevice    58.  4.100 / 58.  4.100
      libavfilter     7. 24.100 /  7. 24.100
      libswscale      5.  2.100 /  5.  2.100
      libswresample   3.  2.100 /  3.  2.100
      libpostproc    55.  2.100 / 55.  2.100
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'concat.mov':
      Metadata:
        major_brand     : qt
        minor_version   : 512
        compatible_brands: qt
        encoder         : Lavf57.83.100
      Duration: 00:04:36.96, start: 0.000000, bitrate: 52428 kb/s
        Stream #0:0(eng): Audio: pcm_s24le (in24 / 0x34326E69), 48000 Hz, stereo, s32 (24 bit), 2304 kb/s (default)
        Metadata:
          handler_name    : DataHandler
        Stream #0:1(eng): Video: mpeg2video (4:2:2) (xd5c / 0x63356478), yuv422p(tv, bt709, top first), 1920x1080 [SAR 1:1 DAR 16:9], 50120 kb/s, 25 fps, 25 tbr, 12800 tbn, 50 tbc (default)
        Metadata:
          encoder         : XDCAM HD422 1080i50
    Stream mapping:
      Stream #0:1 -> #0:0 (mpeg2video (native) -> h264 (libx264))
      Stream #0:0 -> #0:1 (pcm_s24le (native) -> ac3 (native))
    Press [q] to stop, [?] for help
    [libx264 @ 000002332da6dcc0] interlace + weightp is not implemented
    [libx264 @ 000002332da6dcc0] using SAR=1/1
    [libx264 @ 000002332da6dcc0] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2
    [libx264 @ 000002332da6dcc0] profile High 4:2:2, level 4.1, 4:2:2 8-bit
    [libx264 @ 000002332da6dcc0] 264 - core 155 r2901 7d0ff22 - H.264/MPEG-4 AVC codec - Copyleft 2003-2018 - http://www.videolan.org/x264.html - options: cabac=1 ref=3 deblock=1:0:0 analyse=0x3:0x113 me=hex subme=7 psy=1 psy_rd=1.00:0.00 mixed_ref=1 me_range=16 chroma_me=1 trellis=1 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=-2 threads=12 lookahead_threads=2 sliced_threads=0 nr=0 decimate=1 interlaced=tff bluray_compat=0 constrained_intra=0 bframes=2 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=0 keyint=33 keyint_min=3 scenecut=40 intra_refresh=0 rc_lookahead=33 rc=crf mbtree=1 crf=19.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 ip_ratio=1.40 aq=1:1.00
    Output #0, mp4, to 'test.mp4':
      Metadata:
        major_brand     : qt
        minor_version   : 512
        encoder         : Lavf58.15.100
        Stream #0:0(eng): Video: h264 (libx264) (avc1 / 0x31637661), yuv422p(top first), 1920x1080 [SAR 1:1 DAR 16:9], q=-1--1, 25 fps, 12800 tbn, 25 tbc (default)
        Metadata:
          encoder         : Lavc58.19.102 libx264
        Side data:
          cpb: bitrate max/min/avg: 0/0/0 buffer size: 0 vbv_delay: -1
        Stream #0:1(eng): Audio: ac3 (ac-3 / 0x332D6361), 48000 Hz, stereo, fltp (24 bit), 320 kb/s (default)
        Metadata:
          encoder         : Lavc58.19.102 ac3
         frame=  171 fps=6.2 q=24.0 size=    7680kB time=00:00:06.84 bitrate=9194.5kbits/s dup=2 drop=0 speed=0.248x
    The speed encoding is strangely halved respect the same commandline/fileToEncode using my old notebook HP ENVY J113EL (i7 4702MQ 2,20GHz): but during encoding the old HP use 100 CPU (and it encode at 17/18 FPS). Meanwhile this Clevo I7-9700k, teorically much faster, use only the 22 % of CPU and encode at 6/7 fps. Why ?
    I have try also to change the value of
    -threads
    try 0 or 10 or 8 or 12 but nothing... the speed encoding is alwais low: 5-6 Frame per second. Why?!?
  2. Image
    [Attachment 47603 - Click to enlarge]
    also using tmpgenc Video Mastering Work seems that the CPU wont' be used over 19/20%. It's strange because using the HP the CPU is used at 100%
  3. Check another ffmpeg build , also check x264.exe directly
    Did you make sure it's operating as expected with other system benchmark testing suites ?
    Check heat/ temps/fans to ensure no throttling , and make sure it's not on energy saving/lower power modes where clock speed and/or cores can be disabled
  4. ok, however I confirm that the CPU usage from the batch that recall ffmpeg (of course 64bit) is 20/22% instead of 98/100 of the HP
    [Attachment 47605 - Click to enlarge]
  5. please I wonder:
    my CPU is:
    8 phisical core? and 8 virtual? boh
    however, theorically, what is the suitable setting of
    -threads
    "-threads 16" ?
  6. Originally Posted by marcorocchini View Post
    my CPU is:
    8 physical cores, no hyperthreading (no virtual cores).
    -threads
    "-threads 16" ?
    x264 usually likes 1.5x the number of cores (physical + virtual). So 12 in your case. You have some other bottleneck. Even my old quad core i5 2500K gets about 17 fps with 1080i video.
  7. Does Task Manager show 8 CPU graphs when you have View -> CPU History -> One Graph Per CPU selected?
  8. exactly I don't know, in this moment I cannot find "View -> CPU History -> One Graph Per CPU selected?"
    [Attachment 47606 - Click to enlarge]
    however it seems that the problem is a bios limitation current over each CPU. I try to change some settings and seems to improve the speed encoding but the fan goes crazy, and emits a very strong heat, in this case encoding speed become 47 fps (is a encoding 4:2:2 extrafine seamless quality)
    by the task manager seems: 8 core and 8 logical core. So need I to specify a -threads XY value?
  9. Originally Posted by marcorocchini View Post
    i7-9700k does not have HT . It's 8core/8thread
    So what's the problem ? 47fps is faster than 17/18fps on the old laptop
    If loud fans and heat are a problem maybe you shouldn't have bought a laptop . Maybe a desktop with liquid cooling, big radiator, slow quiet fans
  10. Originally Posted by poisondeathray View Post
    7
    no the fan is not a big problem, only are a little noisy. However the setting of -Threads whhat have to be?
    HT = Hyper Cat Treading?
  11. Originally Posted by marcorocchini View Post
    That sounds about right for your CPU.
    I already told you. It's also the default in x264 (and ffmpeg by extension). Look at a MediaInfo report of one of the files you created. It shows the x264 metatdata which includes the number of threads that were used.
  12. Code:
    @set /a cput=((%NUMBER_OF_PROCESSORS%/2)*3)
    and explicitly call this by -threads %cput%
    IMHO you should also set power management profile to high performance, noisy fan and heat are directly linked with CPU load.
    I warned you in previous thread about heat produced during encoding - you should provide additional help to efficiently cool notebook, i recall that more advanced users advised same.
  13. That is why I don't use ffmpeg anymore for video encoding.
    Just for reference, with my setup it pulled 70 fps to encode a 1080p@60 file with your settings:
    ffmpeg -y -threads 9 -i cputest.mov -pix_fmt yuv422p -c:v libx264 -profile:v high422 -level:v 4.1 -g 33 -bf 2 -crf 19 -flags +ildct+ilme -top 1 cputest-sample1.MP4
    frame=15629 fps= 70 q=27.0 size=   93696kB time=00:04:20.36 bitrate=2948.0kbits
    [libx264 @ 00000130384d1fc0] kb/s:2929.54
    Using x264 v2538 it was around 50 fps:
    x264_2538.exe --preset slow --sar 1:1 --threads 9 --input-csp yuv422p --profile high422 --level 4.1 --crf 19 --bframes 2 --keyint 60 --no-interlaced --videoformat component --range pc --vbv-maxrate 4000 --vbv-bufsize 8000 --colorprim bt709 --transfer bt709 --colormatrix bt709 --output-csp i422 --output "cputest-sample2.MP4" "cputest.avs"
    encoded 15640 frames, 50.12 fps, 1759.33 kb/s
    The difference in bitrate reflected the final size, x264=55.5MB and ffmpeg=91.2MB
    Format profile                           : Base Media / Version 2
    Codec ID                                 : mp42 (mp42/mp41/isom)
    File size                                : 55.6 MiB
    Duration                                 : 4 min 20 s
    Overall bit rate                         : 1 789 kb/s
    Encoded date                             : UTC 2018-12-24 16:00:11
    Tagged date                              : UTC 2018-12-24 16:00:11
    Video
    Format profile                           : High 4:2:2@L4.1
    Format settings                          : CABAC / 4 Ref Frames
    Format settings, RefFrames               : 4 frames
    Codec ID                                 : avc1
    Codec ID/Info                            : Advanced Video Coding
    Bit rate                                 : 1 783 kb/s
    Maximum bit rate                         : 3 804 kb/s
    Width                                    : 1 920 pixels
    Height                                   : 1 080 pixels
    Frame rate mode                          : Constant
    Frame rate                               : 60.000 FPS
    Standard                                 : Component
    Chroma subsampling                       : 4:2:2
    Bits/(Pixel*Frame)                       : 0.014
    Stream size                              : 55.4 MiB (100%)
    Writing library                          : x264 core 146 r2538 121396c
    Encoding settings                        : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=9 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=2 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=60 / keyint_min=6 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=19.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=4000 / vbv_bufsize=8000 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
    Color range                              : Full
    Color primaries                          : BT.709
    Transfer characteristics                 : BT.709
    Matrix coefficients                      : BT.709
    Codec configuration box                  : avcC
    ffmpeg (N-91473-gc5329d64b1)
    Codec ID                                 : isom (isom/iso2/avc1/mp41)
    File size                                : 92.3 MiB
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 2 970 kb/s
    Writing application                      : Lavf58.17.101
    Video
    Codec ID                                 : avc1
    Bit rate                                 : 2 930 kb/s
    Scan type                                : MBAFF
    Scan type, store method                  : Interleaved fields
    Scan order                               : Top Field First
    Bits/(Pixel*Frame)                       : 0.024
    Stream size                              : 91.1 MiB (99%)
    Writing library                          : x264 core 155 r2901 7d0ff22
    Encoding settings                        : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=tff / bluray_compat=0 / constrained_intra=0 / bframes=2 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=0 / keyint=33 / keyint_min=3 / scenecut=40 / intra_refresh=0 / rc_lookahead=33 / rc=crf / mbtree=1 / crf=19.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Also related with threads, you set it up to be "9" latter you see that it used "12" among other things you might setup and ffmpeg doesn't follow.
    Quality wise, I see no difference between the two.
    Click on the PC icon to see my setup.
  14. Originally Posted by amaipaipai View Post
    Why different encoder settings was used?
    Aug 2010
    San Francisco, California
    Indeed. Hardly makes it a fair comparison.
  16. Originally Posted by pandy View Post
    Go figure, this is what I was talking about, you set one thing with ffmpeg and you get another.
  17. Originally Posted by amaipaipai View Post
    Also related with threads, you set it up to be "9" and it show it used "12" among other things you might setup and it doesn't follow.
    Are you taking about threads ?
    (lib)x264 threads are not the same thing as ffmpeg threads. ffmpeg does other things, filters, audio etc...those can be threaded too
    If you wanted 9 libx264 threads
    -x264opts threads=9
    Or what else are you talking about ? You should be able to get what you want out of ffmpeg libx264 (with some very minor exceptions, a few things are missing compared to x264 cli)
  18. Originally Posted by amaipaipai View Post
    Well... i see that ffmpeg was forced to perform interlaced encoding where x264 was set to progressive encoding, also seem you missed x264 mapping to ffmpeg https://sites.google.com/site/linuxencoding/x264-ffmpeg-mapping and not using at all private encoder settings (trough -x264opts and trough -x264-params)
    for example:
    @SET x264opts="crf=%vq%:level=4.1:qpmin=8:cabac=1:keyint=infinite:no-deblock=1:no-mbtree=1:me=dia:rc-lookahead=5:ref=3:subme=0:no-weightb=1:weightp=0:trellis=0:no-scenecut=1:no_psnr=1:no_ssim=1:fullrange=on:overscan=show:colorprim=bt709:transfer=bt709:colormatrix=bt709"
    @ffmpeg.exe -hide_banner -v 32 -stats -y -color_range 2 -loop 1 -r 1 -i "%fimage%" -i "%faudio%" -vf %vproc% -c:v libx264 -preset faster -tune stillimage -profile:v high -level:v 4.1 -x264opts %x264opts% -x264-params %x264opts% -color_range 2 -c:a libfdk_aac -b:a 8k -af %aproc% -sn -dn -shortest -movflags faststart -f mp4 "%~n2_%~n1.mp4"
    try to copy encoder setting 1:1 and compare results
  19. Originally Posted by poisondeathray View Post
    Yes, what I meant to say was if you set "A" ffmpeg does "B", if you set threads=9 latter after encoding you see that it was encoded with threads=12, this is just a small example. I don't trust ffmpeg because of that.
    for example:
    Looks interesting
  20. Originally Posted by amaipaipai View Post
    But that was just user error or misunderstanding on your end . ffmpeg threads are not the same thing as libx264 threads
    The syntax for the switches are slightly different but you should be able to get what you want, or translate x264cli to ffmpeg libx264 commands
    Or do you have any other examples where you get "B" instead of "A"
  21. Originally Posted by pandy View Post
    for example:
    This gives a lot of errors, what are the other variables?
    This are the changes I've made so I just drag and drop the file over the .bat:
    cd %~dp0
    @SET fimage=%1
    @ffmpeg.exe -hide_banner -v 32 -stats -y -color_range 2 -r 1 -i "%fimage%" -vf %vproc% -c:v libx264 -preset faster -tune stillimage -profile:v high -level:v 4.1 -x264opts %x264opts% -x264-params %x264opts% -color_range 2 -c:a copy -sn -dn -shortest -movflags faststart -f mp4 "%~n2_%~n1.mp4"
    pause
    It returns:
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'D:\encode\cputest.mov':
      Metadata:
        major_brand     : isom
        minor_version   : 1
        compatible_brands: isom
        creation_time   : 2018-12-22T13:45:10.000000Z
      Duration: 00:04:20.74, start: 0.000000, bitrate: 543 kb/s
        Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuvj420p(pc, bt709/unknown/unknown), 1920x1080 [SAR 1:1 DAR 16:9], 510 kb/s, 60 fps, 60 tbr, 15360 tbn, 120 tbc (default)
        Metadata:
          creation_time   : 2018-12-22T13:43:15.000000Z
          handler_name    : GPAC ISO Video Handler
        Stream #0:1(und): Audio: aac (LC) (mp4a / 0x6134706D), 44100 Hz, stereo, fltp, 25 kb/s (default)
        Metadata:
          creation_time   : 2018-12-22T13:35:06.000000Z
    [NULL @ 000001eec6610980] Unable to find a suitable output format for 'libx264'
    libx264: Invalid argument
    By the way, there is no need for audio just to make this test, we can go just with video for now.
  22. The output is garbage at 1 fps and a 4 min video became a 4h long video with 14.4 kb/s bitrate, ffmpeg is a waste of everybody time.
    File size                                : 27.9 MiB
    Duration                                 : 4 h 20 min
    Overall bit rate                         : 15.0 kb/s
    Video
    Format profile                           : High@L4.1
    Codec ID                                 : avc1
    Bit rate                                 : 14.4 kb/s
    Frame rate                               : 1.000 FPS
    Bits/(Pixel*Frame)                       : 0.007
    Stream size                              : 26.8 MiB (96%)
    Encoding settings                        : cabac=1 / ref=3 / deblock=0:-3:-3 / analyse=0x3:0x113 / me=dia / subme=0 / psy=1 / psy_rd=2.00:0.70 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=0 / open_gop=0 / weightp=0 / keyint=infinite / keyint_min=1 / scenecut=0 / intra_refresh=0 / rc=crf / mbtree=0 / crf=19.0 / qcomp=0.60 / qpmin=8 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.20
    Color range                              : Full
    cd %~dp0
    @SET fimage=%1
    @SET vq=19
    @ffmpeg.exe -hide_banner -v 32 -stats -y -color_range 2 -r 1 -i "%fimage%" -c:v libx264 -preset faster -tune stillimage -profile:v high -level:v 4.1 -x264opts %x264opts% -x264-params %x264opts% -color_range 2 -c:a copy -sn -dn -shortest -movflags faststart -f mp4 "%~n2_%~n1.mp4"
    pause
    Sorry @pandy, I've something better to do, maybe next year.
  23. What are you trying to do ? Did you want to match your x264 settings and convert them to ffmpeg libx264 syntax?
    But there are problems with your x264 settings;
    1) You should be using L4.2 for 1080p60 , L4.1 is "illegal" for 1080p60 and might cause issues with some players
    2) If you use --range pc, that will actually expand the range to pc levels (ie. change actual data from Y 16-235 => 0-255) if --input-range was tv or auto, like it will be for an avs in your commandline . So it's not just a flag in that case , you will get the wrong levels
    But if your script was full range data, and you are wanting to encode full range, you must include --input-range pc as well. That would be full range data, encoded as full range, flagged as full range for x264cli
    Or did you want to convert his settings to x264cli syntax to compare?
    Eitherway - if you want to do a proper comparison, you should do "apples to apples" . So if you use avs as input for x264, you should use avs as input for ffmpeg. If you are using direct video input for ffmpeg you should use --demuxer lavf for x264 with direct video input, you should be using same settings, etc... . I don't know what you're trying to show with completely different settings here...
    If something doesn't work as expected, please report it; because dev's have to know about it in order to fix it. But I don't see any proper commandlines or comparisons. Before making a premature judgement , make sure your tests and methodology are valid first
  24. Originally Posted by poisondeathray View Post
    Hi!
    Pandy ask me to, I don't use ffmpeg for video encoding.
    I'm aware it's illegal.
    Those are me trying to match the OP settings. Since the issue it's not the legality of the OP settings and standards, I did any way.
    That was my setup mixed up with the OP.
    Yes, I use this with my scripts.
    At first I did to try to compare to show the discrepancy.
    The avs is just a "DirectShowSource" so the x264 could understand the file, ffmpeg can handle direct file input that I have.
    The idea was to show that ffmpeg assume options you didn't choose, like the thread option, I set up 9 and ffmpeg assume 12, I didn't setup lookahead and ffmpeg choose lookahead=2 and as you saw it, is a complete different settings even choosing the ones you want.
    I pass.
    This issue is 10 years old at least, the developers are well aware of it, because of this you can't have control since your settings are ignored by ffmpeg. This is why you can't compare it and this is not a premature judgment, people are trusting this peace of **** and are not aware of this. I just don't use it anymore, last time I use it was in 2006 and looks like still has the same issues now in 2018.
    But hey, this is what I think about it, I don't trust it.
    If you have time, try to match the OP settings with x264 and see what you get, in general you get a bigger file with no improvements to justify the extra size.
    Sorry the rush, I'm cooking the Christmas dinner.
    Merry Christmas for you poisondeathray and for everybody, happy holidays everybody.
  25. Originally Posted by amaipaipai View Post
    Just pointing out that he's encoding 1080i25 mbaff (or call it 1080i50 if you want, either way it's 25 frames per second interlaced), which is L4.1.
    You chose a poor example with 1080p60.0 to compare (progressive , wrong frame rate)
    I understand, but best practices is to compare something "apples to apples" as close to as possible, or ceteris paribus
    It negatively impacts the comparison ; avisynth adds at least a bit of overhead , it's a frameserver, consumes resources like memory , cpu cycles. You want to reduce as many variables and differences as possible, otherwise your results are biased and there might be other factors affecting your observations
    What you see is the direct result of your commandline. x264 and libx264 have set default values for things that you don't explicitly include. For example, if you don't set specify a default preset, it will use "medium" . You explicily set --preset slow for your x264cli commandline
    I already explained the threads - You chose 9 ffmpeg threads. You did not specify libx264 threads in your commandline , so it chose "auto." Which is 1.5*cpu cores. I'm assuming you have 8, so 8 * 1.5 = 12
    If you wanted to set libx264, you need to use the command I posted earlier with -x264opts
    For lookahead threads, the "auto" setting is 1/6 of regular threads. Since you had 12 threads for libx264 (because you didn't set it properly, 12/6 = 2)
    I pass.
    ffmpeg has MANY issues, but not the ones your describe in this scenario with ffmpeg libx264. If you have an example where a setting is ignored, please post it
    From what I see, it reacted appropriately according to your commandline.
    In short, I'm asking for concrete examples where something isn't passed or settings are ignored - so we can help improve it if there is a problem. That's all
    That's ok, but I like basing my trust on facts and evidence
    You're using capped crf encoding with vbv (restricting the bitrate --vbv-maxrate 4000 --vbv-bufsize 8000) . That's the main reason why your filesize is lower
    Merry Christmas
  26. One of the op's files from another post
    https://forum.videohelp.com/threads/384431-FFMPEG-why-I-cannot-f-concat-this-2-video-f...e2#post2493088
    C0056.MXF
    Not an exciting "cat" video
    I looped it 8x
    AVS script
    ffvideoSource("C0056.MXF")
    loop(8)
    #2904 frames
    ffmpeg -i C0056.avs -pix_fmt yuv422p -c:v libx264 -profile:v high422 -level:v 4.1 -g 33 -bf 2 -crf 19 -flags +ildct+ilme -top 1 -an ffmpeg_libx264.mp4
    x264k --input-csp i422 --output-csp i422 --level 4.1 --keyint 33 --bframes 2 --crf 19 --tff -o x264cli.mp4 C0056.avs
    Note, I used slightly different x264 libraries r2935 vs. r2833 , and the r2833 has a fade-compensate patch (but set to 0) , but the results are essentially the same. Same filesize. 784MiB. Some differences in the muxer, and mp4 profile, but the point is the same encoding settings passed if you look at the metadata
    Because I did not specify threads, "auto" was used. This is a 4+4HT = 8 cores . So 8*1.5 =12 threads. And look ahead threads is 12/6 =2 . Which is what you get.
    ffmpeg libx264
    Complete name                            : ffmpeg_libx264.mp4
    File size                                : 784 MiB
    Duration                                 : 1 min 56 s
    Overall bit rate                         : 56.6 Mb/s
    Writing application                      : Lavf58.24.101
    Video
    Codec ID                                 : avc1
    Bit rate                                 : 56.1 Mb/s
    Frame rate                               : 25.000 FPS
    Scan type                                : MBAFF
    Bits/(Pixel*Frame)                       : 1.081
    Stream size                              : 784 MiB (100%)
    Writing library                          : x264 core 157 r2935 545de2f
    x264cli
    Complete name                            :x264cli.mp4
    File size                                : 784 MiB
    Video
    Codec ID                                 : avc1
    Maximum bit rate                         : 61.3 Mb/s
    Scan type                                : MBAFF
    Writing library                          : x264 core 150 r2833kMod df79067
    Encoding settings                        : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / fade_compensate=0.00 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=tff / bluray_compat=0 / constrained_intra=0 / bframes=2 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=0 / keyint=33 / keyint_min=3 / scenecut=40 / intra_refresh=0 / rc_lookahead=33 / rc=crf / mbtree=1 / crf=19.0000 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
  27. That looks great poisondeathray, thank you very much to take your time to do all this, much appreciated!!!
    The threads is one of them, if you are telling ffmpeg to use this amount of it, ffmpeg has to limit it self to that. Reasons can be many, control the system heat, resources if I'm doing something else, etc. You said that this must be set in "x264opts", so what the point for ffmpeg to have this settings in the first place if it can't pass it to x264 or whatever encoder the users chooses.
    It can be frame rate or any other setting, ffmpeg ignores the user input unless the user understand that the settings he want, must be pass throughout the use of "xxxops" or similar options. That was the whole deal at the time.
    Yes, that come from the very first script I saw, is the one I use with my Blu-Ray player.
  28. Originally Posted by amaipaipai View Post
    Another way of looking at it is you didn't use the correct commandline
    And you can see it does pass when you use the correct commandline , try the -x264opts threads=9 command.
    And as expected, the lookahead threads is 1, because of the formula 9/6 rounds to 1
    Well, the assumption is the user is supposed to understand how to use ffmpeg. A developer is just going to say "RTFM - It's your problem if you didn't read the instructions" . The documentation sucks to be fair, but at least it has improved quite a bit from 10 years ago. But you need to provide constructive criticism if you want things improved. You need to build a valid case with strong reasoning about why things should be done a certain way, or provide examples of something not working as expected
    ffmpeg can run multiple processes . On a server, the same video might be split off into 4 or 5 different encoding processes simultaneously . A global threads setting might not be appropriate. You might want the sd encode to get 2 threads, the hd thread to get 4 threads, the uhd encode to get 8 threads and so forth. You might even run different encoders simultaneously, a SD DVD encode with MPEG2 concurrently with a web vp9 version. Maybe the x265 version needs more threads than the x264 version. You might want to leave some threads for audio and filter pre processing, etc.. So the encoder specific commands are for that specific encoder . You can't control all that with a single -threads setting
  29. Originally Posted by poisondeathray View Post
    I understand that, I agree with you!
    x264 has a "threads" settings so as ffmpeg, the point that I'm trying to make you understand is that it's redundant and ffmpeg is full of that redundancy.
    Yes, the ffmpeg documentation is another issue on its own as for the help. Do a "ffmpeg -h fullhelp >ffmpeg-help.txt", look for "libx264 AVOptions", now try to find the "threads" settings, there is none, how a regular user should know that "threads" go inside -x264opts? As you can see it's not the case that we don't read the documentation, maybe it's online:
    https://www.ffmpeg.org/ffmpeg-all.html#libx264_002c-libx264rgb
    No, it's not there either.
    The only place I could find "threads" for x264 was inside ffmpeg source code:
    https://www.ffmpeg.org/doxygen/4.1/libx264_8c_source.html
    Inside "AVCodecDefault x264_defaults" line 1038.
    As you can see, it's not a RTFM issue, it's a lack of leadership, it's a lack of organization, if you don't organize your own documentation I imagine how mess up the code is.
    I'm not a software engineer, but since ffmpeg has redundant settings why not do something like this:
    check if user set "threads", if yes check if the encoder uses "threads", if yes use the definition made by user, if not, use defaults.
    Again, I'm not a programmer but you get the idea.
    I'm not trying to build a case, to be scientific about it or to ask for any changes, I'm long gone with ffmpeg, I did help development years ago and I'm done, I don't use it and don't care about it anymore.
    Again, thank you for your time and effort to shed some light on some issues, I hope the forum members make a very goo use of it.
    You have a very good Christmas poisondeathray, you're a very nice guy!
  30. Originally Posted by amaipaipai View Post
    I see what you are saying - and that makes sense to me. , but my general observation is each codec that has it's own settings, tends to ignore the global -threads command . You can submit a suggestion on their tracker if you want to . They kind of already covered their asses like a sly politician
    threads integer (decoding/encoding,video)
    Set the number of threads to be used, in case the selected codec implementation supports multi-threading.
    libavcodec provides some generic global options, which can be set on all the encoders and decoders. In addition each codec may support so-called private options, which are specific for a given codec.
    Sometimes, a global option may only affect a specific kind of codec, and may be nonsensical or ignored by another, so you need to be aware of the meaning of the specified options. Also some options are meant only for decoding or encoding.
    It's pretty vague, right ? Basically sometimes some things work, some don't and might be ignored. Hahaha not very helpful documentation
    And the redundancy , yes, lots of it. For example, there are global codec settings, and encoder specific settings. For example -g is max gop size for any codec at the global level, but each codec tends to have it's own too. For x264 it's keyint (or -x264opts keyint=whatever or -x264-params keyint=whatever)
    But for anyone out there using ffmpeg, the preferred way is to use the codec specific options. Because they are specific to that encoder. If they are not listed in the help, look at the actual encoder library documentation . For anyone familiar with x264cli, it's almost the same thing , just use -x264opts or -x264-params plus whatever switches you used for x264cli . Same with x265 (-x265-params)
    The documentation is a mess, but it's 10x better than it used to be. There are still hundreds of undocumented features/behaviours
