Results 1 to 9 of 9
  1. I've just started experimenting with Vegas Pro 15 Edit, and after I export a video, I sometimes get some glitches. There are small flashing lines across the very top of the screen, and videos don't play properly in programs like VLC (they play extremely slowly and in a jerky manner). Restarting Windows fixes the problem. I assume that the glitches have something to do with my video card (an AMD Radeon HD 7480D). Does anyone know if there's a way to avoid this problem?
  2. A while back I had problems with Vegas glitching after rendering, I ended up changing my settings in Vegas and then it looked fine. I can’t remember exactly what I changed, but I would try googling your issue and something should come up that will tell you what settings to change.
  3. Originally Posted by katnisssarrow View Post
    I already looked it up, but couldn't find anything. That's why I asked here.
    However, I have found out something interesting. If I leave my computer alone for a while and the screensaver comes on, when I start using it again, the glitching is gone.
    Aug 2010
    San Francisco, California
    1. Update your graphics adapter driver.
    2. If that doesn't work, try disabling GPU acceleration in Preferences/Video.
  5. Originally Posted by JVRaines View Post
    I believe that I have the latest version already.
    I might have to try that if it becomes too much of a problem.
    Thank you for the suggestions.
  6. Originally Posted by hbenthow View Post
    Ah ok. Maybe it has something to do with your computer?
  7. Originally Posted by katnisssarrow View Post
    Possibly. It's an older model.
    Mar 2011
    Nova Scotia, Canada
    Now you're getting somewhere, look up your suipported OpenGL/OpenCL etc etc levels for your hardware. It's one thing to say "search and ye shall find", another thing to know what the frak search terms to use.
  9. Originally Posted by Hoser Rob View Post
    I looked up the official page for my GPU, but it doesn't have any information about OpenGL or OpenCL.
    https://www.amd.com/en/support/apu/amd-series-processors/amd-a4-series-apu-for-desktop...adeon-hd-7480d
    I used OpenGL Extensions Viewer to find my OpenGL information, but couldn't make heads or tails of it. Here it is:
    Renderer: AMD Radeon HD 7480D
    Vendor: ATI Technologies Inc.
    Memory: 768 MB
    Version: 4.5.13399 Core Profile Forward-Compatible Context 15.201.1101.1001
    Shading language version: 4.40
    Max texture size: 16384 x 16384
    Max vertex texture image units: 18
    Max texture image units: 18
    Max geometry texture units: 18
    Max anisotropic filtering value: 16
    Max viewport size: 16384 x 16384
    Max Clip Distances: 8
    Max samples: 8
    GL Extensions: 292
    \i0
    GL_ARB_tessellation_shader
    GL_ARB_half_float_pixel
    GL_EXT_compiled_vertex_array
    GL_WIN_swap_hint
    GL_EXT_packed_depth_stencil
    GL_EXT_texture_lod_bias
    GL_EXT_provoking_vertex
    GL_EXT_direct_state_access
    GL_ARB_color_buffer_float
    GL_ARB_shader_image_load_store
    GL_ARB_texture_compression_bptc
    GL_ARB_texture_compression_rgtc
    GL_ARB_draw_instanced
    GL_ARB_derivative_control
    GL_EXT_draw_buffers2
    GL_ARB_viewport_array
    GL_ARB_gpu_shader_fp64
    GL_ARB_pipeline_statistics_query
    GL_EXT_texture_shared_exponent
    GL_ARB_draw_elements_base_vertex
    GL_ARB_arrays_of_arrays
    GL_ARB_vertex_type_10f_11f_11f_rev
    GL_ARB_window_pos
    GL_ARB_explicit_attrib_location
    GL_EXT_texture_env_dot3
    GL_ARB_texture_float
    GL_AMD_blend_minmax_factor
    GL_ARB_texture_snorm
    GL_ARB_point_parameters
    GL_AMD_transform_feedback3_lines_triangles
    GL_EXT_transform_feedback
    GL_ARB_depth_buffer_float
    GL_EXT_bindable_uniform
    GL_EXT_timer_query
    GL_ARB_vertex_buffer_object
    GL_AMD_pinned_memory
    GL_EXT_packed_float
    GL_ARB_pixel_buffer_object
    GL_EXT_texgen_reflection
    WGL_NV_float_buffer
    GL_NV_texture_barrier
    GL_ATI_envmap_bumpmap
    GL_ARB_separate_shader_objects
    GL_ARB_buffer_storage
    GL_AMD_seamless_cubemap_per_texture
    GL_ARB_query_buffer_object
    WGL_EXT_framebuffer_sRGB
    GL_AMD_draw_buffers_blend
    GL_ARB_fragment_program_shadow
    GL_EXT_texture_object
    WGL_EXT_swap_control
    GL_ARB_shading_language_100
    GL_ARB_program_interface_query
    WGL_ARB_extensions_string
    GL_KHR_debug
    GL_ARB_compute_shader
    GL_KTX_buffer_region
    GL_ARB_get_texture_sub_image
    GL_ARB_texture_storage
    GL_EXT_packed_pixels
    GL_EXT_blend_func_separate
    GL_ARB_gpu_shader5
    GL_EXT_texture3D
    GL_ARB_texture_env_crossbar
    GL_AMD_name_gen_delete
    GL_EXT_stencil_wrap
    GL_ATI_fragment_shader
    GL_ARB_ES3_compatibility
    GL_EXT_subtexture
    GL_ARB_texture_swizzle
    GL_ARB_transpose_matrix
    GL_EXT_shader_image_load_store
    GL_AMD_conservative_depth
    GL_EXT_texture_compression_bptc
    GL_EXT_texture_compression_latc
    GL_EXT_texture_compression_s3tc
    GL_EXT_texture_compression_rgtc
    GL_ARB_vertex_program
    GL_EXT_texture_sRGB
    GL_NV_copy_depth_to_color
    WGL_EXT_pixel_format_packed_float
    WGL_EXT_swap_control_tear
    GL_NV_float_buffer
    GL_ARB_texture_rectangle
    GL_ARB_depth_clamp
    GL_ARB_shading_language_packing
    GL_ARB_texture_cube_map_array
    GL_ARB_framebuffer_sRGB
    WGL_ARB_render_texture
    GL_ARB_texture_env_add
    GL_AMD_shader_atomic_counter_ops
    GL_ARB_texture_rg
    GL_ARB_framebuffer_no_attachments
    GL_ARB_blend_func_extended
    GL_ATI_texture_float
    WGL_EXT_extensions_string
    GL_ARB_vertex_attrib_64bit
    GL_EXT_vertex_array
    GL_EXT_texture_sRGB_decode
    GL_ARB_multi_draw_indirect
    GL_ARB_texture_gather
    GL_ARB_half_float_vertex
    GL_SGIS_texture_edge_clamp
    GL_ARB_debug_output
    GL_EXT_copy_texture
    GL_EXT_shadow_funcs
    GL_SGIS_texture_lod
    GL_AMD_debug_output
    GL_EXT_texture_filter_anisotropic
    GL_EXT_pixel_buffer_object
    GL_AMD_framebuffer_sample_positions
    GL_EXT_point_parameters
    GL_EXT_multi_draw_arrays
    WGL_ATI_render_texture_rectangle
    GL_ARB_invalidate_subdata
    GL_EXT_texture_rectangle
    GL_ATI_draw_buffers
    GL_ARB_vertex_array_object
    GL_ARB_explicit_uniform_location
    GL_ARB_shadow
    GL_ARB_vertex_array_bgra
    GL_NV_copy_image
    GL_ARB_shader_texture_lod
    GL_SGIS_generate_mipmap
    GL_EXT_blend_minmax
    WGL_ARB_pixel_format
    GL_ARB_shadow_ambient
    GL_ARB_texture_query_levels
    GL_ARB_point_sprite
    GL_ARB_depth_texture
    GL_ARB_fragment_layer_viewport
    GL_ARB_copy_buffer
    WGL_ARB_make_current_read
    WGL_ARB_pixel_format_float
    GL_KHR_robustness
    GL_ARB_get_program_binary
    GL_ARB_conditional_render_inverted
    GL_ARB_transform_feedback2
    GL_ARB_transform_feedback3
    WGL_ARB_pbuffer
    GL_EXT_vertex_array_bgra
    GL_ARB_vertex_attrib_binding
    GL_ARB_map_buffer_range
    WGL_AMD_gpu_association
    GL_ARB_occlusion_query
    WGL_ARB_create_context
    GL_ARB_fragment_shader
    GL_ARB_draw_buffers
    GL_EXT_texture_lod
    GL_EXT_vertex_attrib_64bit
    GL_ARB_texture_border_clamp
    GL_SUN_multi_draw_arrays
    GL_AMD_vertex_shader_viewport_index
    GL_ARB_copy_image
    GL_NV_half_float
    GL_ARB_vertex_shader
    GL_ARB_texture_mirrored_repeat
    GL_EXT_fog_coord
    GL_NV_explicit_multisample
    GL_AMD_shader_stencil_export
    GL_EXT_framebuffer_blit
    GL_ARB_draw_indirect
    GL_ARB_imaging
    GL_ARB_geometry_shader4
    GL_ATI_separate_stencil
    GL_ARB_shading_language_420pack
    GL_ARB_base_instance
    GL_ARB_texture_env_combine
    GL_EXT_abgr
    GL_EXT_bgra
    GL_ARB_texture_non_power_of_two
    GL_ARB_texture_buffer_object
    GL_EXT_texture_cube_map
    GL_AMD_texture_texture4
    GL_ARB_texture_barrier
    GL_KHR_robust_buffer_access_behavior
    GL_EXT_texture_edge_clamp
    GL_ARB_seamless_cubemap_per_texture
    GL_ARB_sync
    GL_ARB_texture_query_lod
    GL_ARB_clear_buffer_object
    GL_EXT_separate_specular_color
    GL_EXT_framebuffer_object
    GL_EXT_texture_integer
    GL_NV_conditional_render
    GL_ARB_draw_buffers_blend
    GL_ARB_texture_stencil8
    GL_EXT_blend_color
    GL_ARB_sample_shading
    GL_EXT_gpu_program_parameters
    GL_ARB_internalformat_query
    GL_EXT_texture_mirror_clamp
    GL_ARB_timer_query
    GL_ARB_cull_distance
    GL_NV_texgen_reflection
    GL_AMD_query_buffer_object
    GL_KHR_context_flush_control
    GL_NV_depth_buffer_float
    GL_AMD_texture_cube_map_array
    GL_ARB_robust_buffer_access_behavior
    GL_EXT_blend_subtract
    GL_ARB_shader_subroutine
    GL_ARB_conservative_depth
    GL_EXT_gpu_shader4
    WGL_ARB_multisample
    GL_ARB_texture_buffer_range
    GL_EXT_secondary_color
    GL_EXT_texture_storage
    GL_ARB_texture_mirror_clamp_to_edge
    GL_ARB_transform_feedback_overflow_query
    GL_ARB_shader_precision
    GL_ARB_clip_control
    GL_AMD_shader_trace
    GL_EXT_texture_swizzle
    GL_ATI_texture_mirror_once
    GL_ARB_provoking_vertex
    GL_ARB_stencil_texturing
    WGL_ARB_context_flush_control
    GL_ARB_shader_texture_image_samples
    GL_ARB_texture_view
    GL_NV_blend_square
    GL_ARB_internalformat_query2
    GL_OES_EGL_image
    GL_EXT_texture_buffer_object
    GL_ARB_shader_image_size
    WGL_NV_swap_group
    GL_EXT_polygon_offset_clamp
    GL_EXT_texture_env_combine
    GL_EXT_draw_range_elements
    GL_EXT_texture_env_add
    GL_AMDX_debug_output
    GL_AMD_multi_draw_indirect
    GL_AMDX_vertex_shader_tessellator
    GL_AMD_vertex_shader_layer
    GL_ATI_texture_compression_3dc
    GL_ARB_compressed_texture_pixel_storage
    GL_ARB_multisample
    GL_ARB_shader_objects
    GL_AMD_vertex_shader_tessellator
    GL_ARB_ES3_1_compatibility
    WGL_NV_DX_interop
    GL_EXT_geometry_shader4
    GL_ARB_direct_state_access
    GL_AMD_depth_clamp_separate
    GL_ARB_texture_env_dot3
    GL_NV_primitive_restart
    GL_EXT_rescale_normal
    GL_EXT_blend_equation_separate
    GL_ARB_vertex_type_2_10_10_10_rev
    GL_ATI_texture_env_combine3
    GL_ARB_shader_storage_buffer_object
    GL_EXT_draw_instanced
    WGL_ARB_create_context_profile
    WGL_I3D_genlock
    WGL_ARB_buffer_region
    GL_ARB_transform_feedback_instanced
    WGL_ATI_pixel_format_float
    GL_ARB_texture_buffer_object_rgb32
    GL_EXT_histogram
    GL_ARB_instanced_arrays
    GL_ARB_texture_storage_multisample
    GL_IBM_texture_mirrored_repeat
    GL_ARB_shader_stencil_export
    GL_ARB_ES2_compatibility
    GL_ARB_uniform_buffer_object
    GL_EXT_framebuffer_multisample
    GL_EXT_copy_buffer
    GL_ARB_texture_multisample
    GL_ARB_shader_atomic_counters
    GL_EXT_shader_integer_mix
    GL_ARB_map_buffer_alignment
    GL_ARB_sampler_objects
    GL_AMD_sample_positions
    GL_ARB_occlusion_query2
    GL_ARB_framebuffer_object
    GL_ARB_enhanced_layouts
    GL_ARB_multi_bind
    WGL_NV_DX_interop2
    WGL_AMDX_gpu_association
    GL_ARB_multitexture
    GL_EXT_texture_array
    GL_ARB_seamless_cube_map
    GL_EXT_texture_snorm
    GL_ARB_texture_rgb10_a2ui
    GL_ARB_fragment_coord_conventions
    GL_ARB_clear_texture
    GL_AMD_performance_monitor
    GL_ARB_shader_bit_encoding
    Core features
    v3.0 (100 % - 23/23)
    v3.1 (100 % - 8/8)
    v3.2 (100 % - 10/10)
    v3.3 (100 % - 10/10)
    v4.0 (100 % - 14/14)
    v4.1 (100 % - 7/7)
    v4.2 (100 % - 13/13)
    v4.3 (100 % - 23/23)
    v4.4 (100 % - 10/10)
    v4.5 (90 % - 10/11)
    v4.6 (18 % - 2/11)
    vARB 2015 (0 % - 0/12)
    OpenGL driver version check (Current: 0, Latest known: ):
     Latest version of display drivers found
     According the database, you are running the latest display drivers for your video card.
    Extension verification:
     GL_APPLE_texture_range  was not found, but has the entry point  glGetTexParameterPointervAPPLE
     GL_APPLE_texture_range  was not found, but has the entry point  glTextureRangeAPPLE
     GL_NV_gpu_shader5  was not found, but has the entry point  glGetUniformi64vNV
     GL_NV_gpu_shader5  was not found, but has the entry point  glGetUniformui64vNV
     GL_NV_gpu_shader5  was not found, but has the entry point  glProgramUniform1i64NV
     GL_NV_gpu_shader5  was not found, but has the entry point  glProgramUniform1i64vNV
     GL_NV_gpu_shader5  was not found, but has the entry point  glProgramUniform1ui64NV
     GL_NV_gpu_shader5  was not found, but has the entry point  glProgramUniform1ui64vNV
     GL_NV_gpu_shader5  was not found, but has the entry point  glProgramUniform2i64NV
     GL_NV_gpu_shader5  was not found, but has the entry point  glProgramUniform2i64vNV
     GL_NV_gpu_shader5  was not found, but has the entry point  glProgramUniform2ui64NV
     GL_NV_gpu_shader5  was not found, but has the entry point  glProgramUniform2ui64vNV
     GL_NV_gpu_shader5  was not found, but has the entry point  glProgramUniform3i64NV
     GL_NV_gpu_shader5  was not found, but has the entry point  glProgramUniform3i64vNV
     GL_NV_gpu_shader5  was not found, but has the entry point  glProgramUniform3ui64NV
     GL_NV_gpu_shader5  was not found, but has the entry point  glProgramUniform3ui64vNV
     GL_NV_gpu_shader5  was not found, but has the entry point  glProgramUniform4i64NV
     GL_NV_gpu_shader5  was not found, but has the entry point  glProgramUniform4i64vNV
     GL_NV_gpu_shader5  was not found, but has the entry point  glProgramUniform4ui64NV
     GL_NV_gpu_shader5  was not found, but has the entry point  glProgramUniform4ui64vNV
     GL_NV_gpu_shader5  was not found, but has the entry point  glUniform1i64NV
     GL_NV_gpu_shader5  was not found, but has the entry point  glUniform1i64vNV
     GL_NV_gpu_shader5  was not found, but has the entry point  glUniform1ui64NV
     GL_NV_gpu_shader5  was not found, but has the entry point  glUniform1ui64vNV
     GL_NV_gpu_shader5  was not found, but has the entry point  glUniform2i64NV
     GL_NV_gpu_shader5  was not found, but has the entry point  glUniform2i64vNV
     GL_NV_gpu_shader5  was not found, but has the entry point  glUniform2ui64NV
     GL_NV_gpu_shader5  was not found, but has the entry point  glUniform2ui64vNV
     GL_NV_gpu_shader5  was not found, but has the entry point  glUniform3i64NV
     GL_NV_gpu_shader5  was not found, but has the entry point  glUniform3i64vNV
     GL_NV_gpu_shader5  was not found, but has the entry point  glUniform3ui64NV
     GL_NV_gpu_shader5  was not found, but has the entry point  glUniform3ui64vNV
     GL_NV_gpu_shader5  was not found, but has the entry point  glUniform4i64NV
     GL_NV_gpu_shader5  was not found, but has the entry point  glUniform4i64vNV
     GL_NV_gpu_shader5  was not found, but has the entry point  glUniform4ui64NV
     GL_NV_gpu_shader5  was not found, but has the entry point  glUniform4ui64vNV
     GL_EXT_vertex_shader  was not found, but has the entry point  glBeginVertexShaderEXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glBindLightParameterEXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glBindMaterialParameterEXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glBindParameterEXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glBindTexGenParameterEXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glBindTextureUnitParameterEXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glBindVertexShaderEXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glDeleteVertexShaderEXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glDisableVariantClientStateEXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glEnableVariantClientStateEXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glEndVertexShaderEXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glExtractComponentEXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glGenSymbolsEXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glGenVertexShadersEXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glGetInvariantBooleanvEXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glGetInvariantFloatvEXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glGetInvariantIntegervEXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glGetLocalConstantBooleanvEXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glGetLocalConstantFloatvEXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glGetLocalConstantIntegervEXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glGetVariantBooleanvEXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glGetVariantFloatvEXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glGetVariantIntegervEXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glGetVariantPointervEXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glInsertComponentEXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glIsVariantEnabledEXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glSetInvariantEXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glSetLocalConstantEXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glShaderOp1EXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glShaderOp2EXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glShaderOp3EXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glSwizzleEXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glVariantPointerEXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glVariantbvEXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glVariantdvEXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glVariantfvEXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glVariantivEXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glVariantsvEXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glVariantubvEXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glVariantuivEXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glVariantusvEXT
     GL_EXT_vertex_shader  was not found, but has the entry point  glWriteMaskEXT
     GL_ARB_robustness  was not found, but has the entry point  glGetGraphicsResetStatusARB
     GL_ARB_robustness  was not found, but has the entry point  glGetnColorTableARB
     GL_ARB_robustness  was not found, but has the entry point  glGetnCompressedTexImageARB
     GL_ARB_robustness  was not found, but has the entry point  glGetnConvolutionFilterARB
     GL_ARB_robustness  was not found, but has the entry point  glGetnHistogramARB
     GL_ARB_robustness  was not found, but has the entry point  glGetnMapdvARB
     GL_ARB_robustness  was not found, but has the entry point  glGetnMapfvARB
     GL_ARB_robustness  was not found, but has the entry point  glGetnMapivARB
     GL_ARB_robustness  was not found, but has the entry point  glGetnMinmaxARB
     GL_ARB_robustness  was not found, but has the entry point  glGetnPixelMapfvARB
     GL_ARB_robustness  was not found, but has the entry point  glGetnPixelMapuivARB
     GL_ARB_robustness  was not found, but has the entry point  glGetnPixelMapusvARB
     GL_ARB_robustness  was not found, but has the entry point  glGetnPolygonStippleARB
     GL_ARB_robustness  was not found, but has the entry point  glGetnSeparableFilterARB
     GL_ARB_robustness  was not found, but has the entry point  glGetnTexImageARB
     GL_ARB_robustness  was not found, but has the entry point  glGetnUniformdvARB
     GL_ARB_robustness  was not found, but has the entry point  glGetnUniformfvARB
     GL_ARB_robustness  was not found, but has the entry point  glGetnUniformivARB
     GL_ARB_robustness  was not found, but has the entry point  glGetnUniformuivARB
     GL_ARB_robustness  was not found, but has the entry point  glReadnPixelsARB
     GL_AMD_stencil_operation_extended  was not found, but has the entry point  glStencilOpValueAMD
     GL_VERSION_1_2  was not found, but has the entry point  glCopyTexSubImage3D
     GL_VERSION_1_2  was not found, but has the entry point  glDrawRangeElements
     GL_VERSION_1_2  was not found, but has the entry point  glTexImage3D
     GL_VERSION_1_2  was not found, but has the entry point  glTexSubImage3D
     GL_VERSION_1_3  was not found, but has the entry point  glActiveTexture
     GL_VERSION_1_3  was not found, but has the entry point  glClientActiveTexture
     GL_VERSION_1_3  was not found, but has the entry point  glCompressedTexImage1D
     GL_VERSION_1_3  was not found, but has the entry point  glCompressedTexImage2D
     GL_VERSION_1_3  was not found, but has the entry point  glCompressedTexImage3D
     GL_VERSION_1_3  was not found, but has the entry point  glCompressedTexSubImage1D
     GL_VERSION_1_3  was not found, but has the entry point  glCompressedTexSubImage2D
     GL_VERSION_1_3  was not found, but has the entry point  glCompressedTexSubImage3D
     GL_VERSION_1_3  was not found, but has the entry point  glGetCompressedTexImage
     GL_VERSION_1_3  was not found, but has the entry point  glLoadTransposeMatrixd
     GL_VERSION_1_3  was not found, but has the entry point  glLoadTransposeMatrixf
     GL_VERSION_1_3  was not found, but has the entry point  glMultTransposeMatrixd
     GL_VERSION_1_3  was not found, but has the entry point  glMultTransposeMatrixf
     GL_VERSION_1_3  was not found, but has the entry point  glMultiTexCoord1d
     GL_VERSION_1_3  was not found, but has the entry point  glMultiTexCoord1dv
     GL_VERSION_1_3  was not found, but has the entry point  glMultiTexCoord1f
     GL_VERSION_1_3  was not found, but has the entry point  glMultiTexCoord1fv
     GL_VERSION_1_3  was not found, but has the entry point  glMultiTexCoord1i
     GL_VERSION_1_3  was not found, but has the entry point  glMultiTexCoord1iv
     GL_VERSION_1_3  was not found, but has the entry point  glMultiTexCoord1s
     GL_VERSION_1_3  was not found, but has the entry point  glMultiTexCoord1sv
     GL_VERSION_1_3  was not found, but has the entry point  glMultiTexCoord2d
     GL_VERSION_1_3  was not found, but has the entry point  glMultiTexCoord2dv
     GL_VERSION_1_3  was not found, but has the entry point  glMultiTexCoord2f
     GL_VERSION_1_3  was not found, but has the entry point  glMultiTexCoord2fv
     GL_VERSION_1_3  was not found, but has the entry point  glMultiTexCoord2i
     GL_VERSION_1_3  was not found, but has the entry point  glMultiTexCoord2iv
     GL_VERSION_1_3  was not found, but has the entry point  glMultiTexCoord2s
     GL_VERSION_1_3  was not found, but has the entry point  glMultiTexCoord2sv
     GL_VERSION_1_3  was not found, but has the entry point  glMultiTexCoord3d
     GL_VERSION_1_3  was not found, but has the entry point  glMultiTexCoord3dv
     GL_VERSION_1_3  was not found, but has the entry point  glMultiTexCoord3f
     GL_VERSION_1_3  was not found, but has the entry point  glMultiTexCoord3fv
     GL_VERSION_1_3  was not found, but has the entry point  glMultiTexCoord3i
     GL_VERSION_1_3  was not found, but has the entry point  glMultiTexCoord3iv
     GL_VERSION_1_3  was not found, but has the entry point  glMultiTexCoord3s
     GL_VERSION_1_3  was not found, but has the entry point  glMultiTexCoord3sv
     GL_VERSION_1_3  was not found, but has the entry point  glMultiTexCoord4d
     GL_VERSION_1_3  was not found, but has the entry point  glMultiTexCoord4dv
     GL_VERSION_1_3  was not found, but has the entry point  glMultiTexCoord4f
     GL_VERSION_1_3  was not found, but has the entry point  glMultiTexCoord4fv
     GL_VERSION_1_3  was not found, but has the entry point  glMultiTexCoord4i
     GL_VERSION_1_3  was not found, but has the entry point  glMultiTexCoord4iv
     GL_VERSION_1_3  was not found, but has the entry point  glMultiTexCoord4s
     GL_VERSION_1_3  was not found, but has the entry point  glMultiTexCoord4sv
     GL_VERSION_1_3  was not found, but has the entry point  glSampleCoverage
     GL_VERSION_1_4  was not found, but has the entry point  glBlendColor
     GL_VERSION_1_4  was not found, but has the entry point  glBlendEquation
     GL_VERSION_1_4  was not found, but has the entry point  glBlendFuncSeparate
     GL_VERSION_1_4  was not found, but has the entry point  glFogCoordPointer
     GL_VERSION_1_4  was not found, but has the entry point  glFogCoordd
     GL_VERSION_1_4  was not found, but has the entry point  glFogCoorddv
     GL_VERSION_1_4  was not found, but has the entry point  glFogCoordf
     GL_VERSION_1_4  was not found, but has the entry point  glFogCoordfv
     GL_VERSION_1_4  was not found, but has the entry point  glMultiDrawArrays
     GL_VERSION_1_4  was not found, but has the entry point  glMultiDrawElements
     GL_VERSION_1_4  was not found, but has the entry point  glPointParameterf
     GL_VERSION_1_4  was not found, but has the entry point  glPointParameterfv
     GL_VERSION_1_4  was not found, but has the entry point  glPointParameteri
     GL_VERSION_1_4  was not found, but has the entry point  glPointParameteriv
     GL_VERSION_1_4  was not found, but has the entry point  glSecondaryColor3b
     GL_VERSION_1_4  was not found, but has the entry point  glSecondaryColor3bv
     GL_VERSION_1_4  was not found, but has the entry point  glSecondaryColor3d
     GL_VERSION_1_4  was not found, but has the entry point  glSecondaryColor3dv
     GL_VERSION_1_4  was not found, but has the entry point  glSecondaryColor3f
     GL_VERSION_1_4  was not found, but has the entry point  glSecondaryColor3fv
     GL_VERSION_1_4  was not found, but has the entry point  glSecondaryColor3i
     GL_VERSION_1_4  was not found, but has the entry point  glSecondaryColor3iv
     GL_VERSION_1_4  was not found, but has the entry point  glSecondaryColor3s
     GL_VERSION_1_4  was not found, but has the entry point  glSecondaryColor3sv
     GL_VERSION_1_4  was not found, but has the entry point  glSecondaryColor3ub
     GL_VERSION_1_4  was not found, but has the entry point  glSecondaryColor3ubv
     GL_VERSION_1_4  was not found, but has the entry point  glSecondaryColor3ui
     GL_VERSION_1_4  was not found, but has the entry point  glSecondaryColor3uiv
     GL_VERSION_1_4  was not found, but has the entry point  glSecondaryColor3us
     GL_VERSION_1_4  was not found, but has the entry point  glSecondaryColor3usv
     GL_VERSION_1_4  was not found, but has the entry point  glSecondaryColorPointer
     GL_VERSION_1_4  was not found, but has the entry point  glWindowPos2d
     GL_VERSION_1_4  was not found, but has the entry point  glWindowPos2dv
     GL_VERSION_1_4  was not found, but has the entry point  glWindowPos2f
     GL_VERSION_1_4  was not found, but has the entry point  glWindowPos2fv
     GL_VERSION_1_4  was not found, but has the entry point  glWindowPos2i
     GL_VERSION_1_4  was not found, but has the entry point  glWindowPos2iv
     GL_VERSION_1_4  was not found, but has the entry point  glWindowPos2s
     GL_VERSION_1_4  was not found, but has the entry point  glWindowPos2sv
     GL_VERSION_1_4  was not found, but has the entry point  glWindowPos3d
     GL_VERSION_1_4  was not found, but has the entry point  glWindowPos3dv
     GL_VERSION_1_4  was not found, but has the entry point  glWindowPos3f
     GL_VERSION_1_4  was not found, but has the entry point  glWindowPos3fv
     GL_VERSION_1_4  was not found, but has the entry point  glWindowPos3i
     GL_VERSION_1_4  was not found, but has the entry point  glWindowPos3iv
     GL_VERSION_1_4  was not found, but has the entry point  glWindowPos3s
     GL_VERSION_1_4  was not found, but has the entry point  glWindowPos3sv
     GL_VERSION_1_5  was not found, but has the entry point  glBeginQuery
     GL_VERSION_1_5  was not found, but has the entry point  glBindBuffer
     GL_VERSION_1_5  was not found, but has the entry point  glBufferData
     GL_VERSION_1_5  was not found, but has the entry point  glBufferSubData
     GL_VERSION_1_5  was not found, but has the entry point  glDeleteBuffers
     GL_VERSION_1_5  was not found, but has the entry point  glDeleteQueries
     GL_VERSION_1_5  was not found, but has the entry point  glEndQuery
     GL_VERSION_1_5  was not found, but has the entry point  glGenBuffers
     GL_VERSION_1_5  was not found, but has the entry point  glGenQueries
     GL_VERSION_1_5  was not found, but has the entry point  glGetBufferParameteriv
     GL_VERSION_1_5  was not found, but has the entry point  glGetBufferPointerv
     GL_VERSION_1_5  was not found, but has the entry point  glGetBufferSubData
     GL_VERSION_1_5  was not found, but has the entry point  glGetQueryObjectiv
     GL_VERSION_1_5  was not found, but has the entry point  glGetQueryObjectuiv
     GL_VERSION_1_5  was not found, but has the entry point  glGetQueryiv
     GL_VERSION_1_5  was not found, but has the entry point  glIsBuffer
     GL_VERSION_1_5  was not found, but has the entry point  glIsQuery
     GL_VERSION_1_5  was not found, but has the entry point  glMapBuffer
     GL_VERSION_1_5  was not found, but has the entry point  glUnmapBuffer
     GL_VERSION_2_0  was not found, but has the entry point  glAttachShader
     GL_VERSION_2_0  was not found, but has the entry point  glBindAttribLocation
     GL_VERSION_2_0  was not found, but has the entry point  glBlendEquationSeparate
     GL_VERSION_2_0  was not found, but has the entry point  glCompileShader
     GL_VERSION_2_0  was not found, but has the entry point  glCreateProgram
     GL_VERSION_2_0  was not found, but has the entry point  glCreateShader
     GL_VERSION_2_0  was not found, but has the entry point  glDeleteProgram
     GL_VERSION_2_0  was not found, but has the entry point  glDeleteShader
     GL_VERSION_2_0  was not found, but has the entry point  glDetachShader
     GL_VERSION_2_0  was not found, but has the entry point  glDisableVertexAttribArray
     GL_VERSION_2_0  was not found, but has the entry point  glDrawBuffers
     GL_VERSION_2_0  was not found, but has the entry point  glEnableVertexAttribArray
     GL_VERSION_2_0  was not found, but has the entry point  glGetActiveAttrib
     GL_VERSION_2_0  was not found, but has the entry point  glGetActiveUniform
     GL_VERSION_2_0  was not found, but has the entry point  glGetAttachedShaders
     GL_VERSION_2_0  was not found, but has the entry point  glGetAttribLocation
     GL_VERSION_2_0  was not found, but has the entry point  glGetProgramInfoLog
     GL_VERSION_2_0  was not found, but has the entry point  glGetProgramiv
     GL_VERSION_2_0  was not found, but has the entry point  glGetShaderInfoLog
     GL_VERSION_2_0  was not found, but has the entry point  glGetShaderSource
     GL_VERSION_2_0  was not found, but has the entry point  glGetShaderiv
     GL_VERSION_2_0  was not found, but has the entry point  glGetUniformLocation
     GL_VERSION_2_0  was not found, but has the entry point  glGetUniformfv
     GL_VERSION_2_0  was not found, but has the entry point  glGetUniformiv
     GL_VERSION_2_0  was not found, but has the entry point  glGetVertexAttribPointerv
     GL_VERSION_2_0  was not found, but has the entry point  glGetVertexAttribdv
     GL_VERSION_2_0  was not found, but has the entry point  glGetVertexAttribfv
     GL_VERSION_2_0  was not found, but has the entry point  glGetVertexAttribiv
     GL_VERSION_2_0  was not found, but has the entry point  glIsProgram
     GL_VERSION_2_0  was not found, but has the entry point  glIsShader
     GL_VERSION_2_0  was not found, but has the entry point  glLinkProgram
     GL_VERSION_2_0  was not found, but has the entry point  glShaderSource
     GL_VERSION_2_0  was not found, but has the entry point  glStencilFuncSeparate
     GL_VERSION_2_0  was not found, but has the entry point  glStencilMaskSeparate
     GL_VERSION_2_0  was not found, but has the entry point  glStencilOpSeparate
     GL_VERSION_2_0  was not found, but has the entry point  glUniform1f
     GL_VERSION_2_0  was not found, but has the entry point  glUniform1fv
     GL_VERSION_2_0  was not found, but has the entry point  glUniform1i
     GL_VERSION_2_0  was not found, but has the entry point  glUniform1iv
     GL_VERSION_2_0  was not found, but has the entry point  glUniform2f
     GL_VERSION_2_0  was not found, but has the entry point  glUniform2fv
     GL_VERSION_2_0  was not found, but has the entry point  glUniform2i
     GL_VERSION_2_0  was not found, but has the entry point  glUniform2iv
     GL_VERSION_2_0  was not found, but has the entry point  glUniform3f
     GL_VERSION_2_0  was not found, but has the entry point  glUniform3fv
     GL_VERSION_2_0  was not found, but has the entry point  glUniform3i
     GL_VERSION_2_0  was not found, but has the entry point  glUniform3iv
     GL_VERSION_2_0  was not found, but has the entry point  glUniform4f
     GL_VERSION_2_0  was not found, but has the entry point  glUniform4fv
     GL_VERSION_2_0  was not found, but has the entry point  glUniform4i
     GL_VERSION_2_0  was not found, but has the entry point  glUniform4iv
     GL_VERSION_2_0  was not found, but has the entry point  glUniformMatrix2fv
     GL_VERSION_2_0  was not found, but has the entry point  glUniformMatrix3fv
     GL_VERSION_2_0  was not found, but has the entry point  glUniformMatrix4fv
     GL_VERSION_2_0  was not found, but has the entry point  glUseProgram
     GL_VERSION_2_0  was not found, but has the entry point  glValidateProgram
     GL_VERSION_2_0  was not found, but has the entry point  glVertexAttrib1d
     GL_VERSION_2_0  was not found, but has the entry point  glVertexAttrib1dv
     GL_VERSION_2_0  was not found, but has the entry point  glVertexAttrib1f
     GL_VERSION_2_0  was not found, but has the entry point  glVertexAttrib1fv
     GL_VERSION_2_0  was not found, but has the entry point  glVertexAttrib1s
     GL_VERSION_2_0  was not found, but has the entry point  glVertexAttrib1sv
     GL_VERSION_2_0  was not found, but has the entry point  glVertexAttrib2d
     GL_VERSION_2_0  was not found, but has the entry point  glVertexAttrib2dv
     GL_VERSION_2_0  was not found, but has the entry point  glVertexAttrib2f
     GL_VERSION_2_0  was not found, but has the entry point  glVertexAttrib2fv
     GL_VERSION_2_0  was not found, but has the entry point  glVertexAttrib2s
     GL_VERSION_2_0  was not found, but has the entry point  glVertexAttrib2sv
     GL_VERSION_2_0  was not found, but has the entry point  glVertexAttrib3d
     GL_VERSION_2_0  was not found, but has the entry point  glVertexAttrib3dv
     GL_VERSION_2_0  was not found, but has the entry point  glVertexAttrib3f
     GL_VERSION_2_0  was not found, but has the entry point  glVertexAttrib3fv
     GL_VERSION_2_0  was not found, but has the entry point  glVertexAttrib3s
     GL_VERSION_2_0  was not found, but has the entry point  glVertexAttrib3sv
     GL_VERSION_2_0  was not found, but has the entry point  glVertexAttrib4Nbv
     GL_VERSION_2_0  was not found, but has the entry point  glVertexAttrib4Niv
     GL_VERSION_2_0  was not found, but has the entry point  glVertexAttrib4Nsv
     GL_VERSION_2_0  was not found, but has the entry point  glVertexAttrib4Nub
     GL_VERSION_2_0  was not found, but has the entry point  glVertexAttrib4Nubv
     GL_VERSION_2_0  was not found, but has the entry point  glVertexAttrib4Nuiv
     GL_VERSION_2_0  was not found, but has the entry point  glVertexAttrib4Nusv
     GL_VERSION_2_0  was not found, but has the entry point  glVertexAttrib4bv
     GL_VERSION_2_0  was not found, but has the entry point  glVertexAttrib4d
     GL_VERSION_2_0  was not found, but has the entry point  glVertexAttrib4dv
     GL_VERSION_2_0  was not found, but has the entry point  glVertexAttrib4f
     GL_VERSION_2_0  was not found, but has the entry point  glVertexAttrib4fv
     GL_VERSION_2_0  was not found, but has the entry point  glVertexAttrib4iv
     GL_VERSION_2_0  was not found, but has the entry point  glVertexAttrib4s
     GL_VERSION_2_0  was not found, but has the entry point  glVertexAttrib4sv
     GL_VERSION_2_0  was not found, but has the entry point  glVertexAttrib4ubv
     GL_VERSION_2_0  was not found, but has the entry point  glVertexAttrib4uiv
     GL_VERSION_2_0  was not found, but has the entry point  glVertexAttrib4usv
     GL_VERSION_2_0  was not found, but has the entry point  glVertexAttribPointer
     GL_VERSION_2_1  was not found, but has the entry point  glUniformMatrix2x3fv
     GL_VERSION_2_1  was not found, but has the entry point  glUniformMatrix2x4fv
     GL_VERSION_2_1  was not found, but has the entry point  glUniformMatrix3x2fv
     GL_VERSION_2_1  was not found, but has the entry point  glUniformMatrix3x4fv
     GL_VERSION_2_1  was not found, but has the entry point  glUniformMatrix4x2fv
     GL_VERSION_2_1  was not found, but has the entry point  glUniformMatrix4x3fv
     GL_VERSION_3_0  was not found, but has the entry point  glBeginConditionalRender
     GL_VERSION_3_0  was not found, but has the entry point  glBeginTransformFeedback
     GL_VERSION_3_0  was not found, but has the entry point  glBindFragDataLocation
     GL_VERSION_3_0  was not found, but has the entry point  glClampColor
     GL_VERSION_3_0  was not found, but has the entry point  glClearBufferfi
     GL_VERSION_3_0  was not found, but has the entry point  glClearBufferfv
     GL_VERSION_3_0  was not found, but has the entry point  glClearBufferiv
     GL_VERSION_3_0  was not found, but has the entry point  glClearBufferuiv
     GL_VERSION_3_0  was not found, but has the entry point  glColorMaski
     GL_VERSION_3_0  was not found, but has the entry point  glDisablei
     GL_VERSION_3_0  was not found, but has the entry point  glEnablei
     GL_VERSION_3_0  was not found, but has the entry point  glEndConditionalRender
     GL_VERSION_3_0  was not found, but has the entry point  glEndTransformFeedback
     GL_VERSION_3_0  was not found, but has the entry point  glGetBooleani_v
     GL_VERSION_3_0  was not found, but has the entry point  glGetFragDataLocation
     GL_VERSION_3_0  was not found, but has the entry point  glGetStringi
     GL_VERSION_3_0  was not found, but has the entry point  glGetTexParameterIiv
     GL_VERSION_3_0  was not found, but has the entry point  glGetTexParameterIuiv
     GL_VERSION_3_0  was not found, but has the entry point  glGetTransformFeedbackVarying
     GL_VERSION_3_0  was not found, but has the entry point  glGetUniformuiv
     GL_VERSION_3_0  was not found, but has the entry point  glGetVertexAttribIiv
     GL_VERSION_3_0  was not found, but has the entry point  glGetVertexAttribIuiv
     GL_VERSION_3_0  was not found, but has the entry point  glIsEnabledi
     GL_VERSION_3_0  was not found, but has the entry point  glTexParameterIiv
     GL_VERSION_3_0  was not found, but has the entry point  glTexParameterIuiv
     GL_VERSION_3_0  was not found, but has the entry point  glTransformFeedbackVaryings
     GL_VERSION_3_0  was not found, but has the entry point  glUniform1ui
     GL_VERSION_3_0  was not found, but has the entry point  glUniform1uiv
     GL_VERSION_3_0  was not found, but has the entry point  glUniform2ui
     GL_VERSION_3_0  was not found, but has the entry point  glUniform2uiv
     GL_VERSION_3_0  was not found, but has the entry point  glUniform3ui
     GL_VERSION_3_0  was not found, but has the entry point  glUniform3uiv
     GL_VERSION_3_0  was not found, but has the entry point  glUniform4ui
     GL_VERSION_3_0  was not found, but has the entry point  glUniform4uiv
     GL_VERSION_3_0  was not found, but has the entry point  glVertexAttribI1i
     GL_VERSION_3_0  was not found, but has the entry point  glVertexAttribI1iv
     GL_VERSION_3_0  was not found, but has the entry point  glVertexAttribI1ui
     GL_VERSION_3_0  was not found, but has the entry point  glVertexAttribI1uiv
     GL_VERSION_3_0  was not found, but has the entry point  glVertexAttribI2i
     GL_VERSION_3_0  was not found, but has the entry point  glVertexAttribI2iv
     GL_VERSION_3_0  was not found, but has the entry point  glVertexAttribI2ui
     GL_VERSION_3_0  was not found, but has the entry point  glVertexAttribI2uiv
     GL_VERSION_3_0  was not found, but has the entry point  glVertexAttribI3i
     GL_VERSION_3_0  was not found, but has the entry point  glVertexAttribI3iv
     GL_VERSION_3_0  was not found, but has the entry point  glVertexAttribI3ui
     GL_VERSION_3_0  was not found, but has the entry point  glVertexAttribI3uiv
     GL_VERSION_3_0  was not found, but has the entry point  glVertexAttribI4bv
     GL_VERSION_3_0  was not found, but has the entry point  glVertexAttribI4i
     GL_VERSION_3_0  was not found, but has the entry point  glVertexAttribI4iv
     GL_VERSION_3_0  was not found, but has the entry point  glVertexAttribI4sv
     GL_VERSION_3_0  was not found, but has the entry point  glVertexAttribI4ubv
     GL_VERSION_3_0  was not found, but has the entry point  glVertexAttribI4ui
     GL_VERSION_3_0  was not found, but has the entry point  glVertexAttribI4uiv
     GL_VERSION_3_0  was not found, but has the entry point  glVertexAttribI4usv
     GL_VERSION_3_0  was not found, but has the entry point  glVertexAttribIPointer
     GL_VERSION_3_1  was not found, but has the entry point  glDrawArraysInstanced
     GL_VERSION_3_1  was not found, but has the entry point  glDrawElementsInstanced
     GL_VERSION_3_1  was not found, but has the entry point  glPrimitiveRestartIndex
     GL_VERSION_3_1  was not found, but has the entry point  glTexBuffer
     GL_VERSION_3_2  was not found, but has the entry point  glFramebufferTexture
     GL_VERSION_3_2  was not found, but has the entry point  glGetBufferParameteri64v
     GL_VERSION_3_2  was not found, but has the entry point  glGetInteger64i_v
     GL_VERSION_3_3  was not found, but has the entry point  glVertexAttribDivisor
     GL_VERSION_4_0  was not found, but has the entry point  glBlendEquationSeparatei
     GL_VERSION_4_0  was not found, but has the entry point  glBlendEquationi
     GL_VERSION_4_0  was not found, but has the entry point  glBlendFuncSeparatei
     GL_VERSION_4_0  was not found, but has the entry point  glBlendFunci
     GL_VERSION_4_0  was not found, but has the entry point  glMinSampleShading
     GL_EXT_depth_bounds_test  was not found, but has the entry point  glDepthBoundsEXT
