Sorry your Transition image was not available to me for some unknown reason.. just appeared now.. and i can see you have given size options in it and type of videos along with codecs choice for containers too (Y) Just add "Frames |Check Box| per second" there plz.
Results 31 to 39 of 39
Also adding a Check Box just before words "Transition to Video" shall be sufficient. Symbol -> there is not needed.
Thanks so much for the suggestions. I fixed a couple bugs in it and will add the random option suggestion. Good Idea. Also maybe auto-load an image folder instead of one at a time.
Always welcome.. will be able to suggest more when next design image you post. Now let me try *.flac in place of *.mp3 but as for my limited knowledge says the output container is mp4 which has the ability to have aac, ac3, mp3 in it but what shall happen to WAV and FLAC audio in the script you gave us above? Will the output container need to be changed to MPEG or AVI ?? anyone plz.
one at a time can give us option to get images from various folders for various songs which folder option cant. However another option can be given in interface .. "Load Image" .. "Load Folder" OR you can give another better option like "One Image for All" and its field box in front of it in the same line. In next line you can give 2 options.. "Select Image" .&. "Images from Folder"
well, i tried adding flac instead of mp3 via batch file. there came an alert that adding flac to mp4 is experimental but you can add -strict -2 if you want to do that.. which i did.. there was an mp4 output after some 6 minutes at the speed of 1x ..and it did play on MPC
but when i uploaded it on facebook.. it had no audio there.. i assume that some encoding issue of facebook ..i mean who expects a flac inside an mp4
so what should i do now for my flac and wav files?
You can use a more common audio codec such as AAC or AC3. Change the script from -acodec copy to another audio codec (-acodec aac). This will recode the audio as aac output instead of just copying it. .
Software that converts mp3 to mp4 and uses liner art for image
By Julius Crouch in forum AudioReplies: 3Last Post: 22nd Dec 2018, 06:17 -
Need Help to Convert 600 mp3 to mp4 with just one still pic in it for YT
By Love in forum AudioReplies: 15Last Post: 21st Dec 2018, 11:09 -
convert mp3 to mp4 and add picture
By kasfig in forum AudioReplies: 8Last Post: 14th Oct 2017, 23:47 -
Taking the pictures/album art out of a mp3 or audio files id3 tagging?
By SyncroScales in forum AudioReplies: 2Last Post: 23rd Sep 2017, 04:28 -
App that embeds art into mp3
By mol3000 in forum AudioReplies: 1Last Post: 16th Sep 2017, 01:06
