Hello,
I'm planning on capturing a video recorded on a Sony PAL camera. This camera supports Hi8 XR.
Now, after reading up a bit I know I should be capturing a video from a Hi8 tape at 768x576. Is it higher for Hi8 XR, or the same?
If you were to check on the XR spec you would see that it just provides for a modest 10% improvement in luminance.
Maximum PAL resolution remains at 768*576 but few capture devices support that. So even if the camera recorded at that (which I also doubt) you capture at 720*576 or 702*576.
Both of the these will ultimately display at 768*576 for 4:3 DAR
Can a PAL DVD Recorder capture signals from a NTSC Hi8 camcorder?
By guy24s in forum DVD & Blu-ray RecordersReplies: 8Last Post: 3rd Dec 2018, 09:33 -
best quality playback and capture for preserving PAL Hi8 camcorder footage?
By HuBanfiT in forum Capturing and VCRReplies: 13Last Post: 29th Jul 2018, 21:24 -
PAL DVD video is 1024 x 576 - wrong resolution?
By draig-llofrudd in forum Video ConversionReplies: 13Last Post: 6th Dec 2016, 17:27 -
hi8 and Digital Hi8 backup help needed.
By SQWIB in forum Capturing and VCRReplies: 5Last Post: 8th Jul 2016, 18:13 -
High-end HI8 deck / camcorder to capture PAL video8 tapes
By FLP437 in forum Capturing and VCRReplies: 2Last Post: 29th Mar 2016, 10:28
