In Subtitle Edit, how can I replace something only in selected lines, not the whole subtitles?
I want to delete every "." in some selected lines.
Just highlight the lines manually, usual control key select as in Windows text files then "find and replace"
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
In Subtitle Edit go to EDIT menu and select Replace. Then your "." (without the quotes of course) and hit the replace button, not the replace all. Leave the field Replace with blank. Do this for each line. There is a menu item under EDIT called Multiple Replace, look up the help file for setting that up but I suspect you will have to do it manually. Never had to do it so haven't explored. It works quite well I removed ( from the first, third and twelfth lines of a subtitle file I have .
It would seem you are going to select those 500 lines manually anyway unless they are in a contiguous block. So how many lines altogether? It *might* be easier to do the whole subtitle file and then add back in where you need "." ? Posible in the Multiple Replace there is a way you can write a rule?
I solved it by copying the selected lines to another empty file, then did the replace, and then I copied the lines back
Pixelated and laggy video on Subtitle Workshop and Subtitle Edit
By Valerc in forum SubtitleReplies: 5Last Post: 15th Jul 2018, 11:37 -
BATCH that find and replace text between [DDRAWSINC] and [
By marcorocchini in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2016, 07:31 -
how to find and replace (add a REM) a text string inside a txt file?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 10th Nov 2015, 15:58 -
multiavchd-how to replace music during menu selection
By mysts in forum Authoring (Blu-ray)Replies: 2Last Post: 25th Mar 2015, 16:55 -
How to convert BD or DVD to mkv with subtitle selection
By vhwul62 in forum Newbie / General discussionsReplies: 2Last Post: 13th Sep 2014, 09:48
