This might be a little difficult to explain. Hope you can understand me, anyways. You know how you can arrange individual clips in the Pot player Playlist by going to "Sort" and then choosing how you want these clips to be arranged in a particular way, either by "Title", "Name", "Extension", " "Size", etc? Well, I was wondering if the same thing can be done for multiple clips from the same folder. For example, say I wanted to move an entire group of clips from the top of of my playlist all the way to the bottom. Is there an easy way to do this without having to move each clip one at a time?
Results 1 to 1 of 1
PotPlayer playlist confusion
By TBacker in forum Software PlayingReplies: 0Last Post: 16th Jul 2018, 00:04 -
Potplayer playlist bug/problem
By AsadAlrafidain in forum Newbie / General discussionsReplies: 0Last Post: 6th Jul 2018, 05:51 -
PotPlayer: Advancing the Playlist issue
By lemings in forum Software PlayingReplies: 1Last Post: 22nd Jun 2017, 14:40 -
potplayer add the playlist shortcut ?
By albatros44 in forum Software PlayingReplies: 0Last Post: 11th Aug 2015, 14:13 -
Why can't I move subtitles in PotPlayer?
By andrew732 in forum Newbie / General discussionsReplies: 7Last Post: 12th Feb 2014, 23:44
