I followed the intructions on the vcd divx->VCD convertig guide. The audio extracted fine with Virtualdb, and I was able to see the video when using TMPGEnc. But after conversion to MPEG, i opened it up in Windows Media PLayer and I only get the audio and black blank screen for video. What cuold be the issue?
sounds like you didbn't load it right go back into tmpgenc if you haven't used it since this problem and see if you loaded avi, wav, and output as well as template
We were all NEWBIES once and the only stupid question is the one that's not asked? -
i ended up burning the mpeg just to see if it works, and the video showed up on my dvd player. as long as it works on the dvd player its ok. and iloaded the output and input corectly from b4.. oh well. thanx.
I'm glad it works
Convert AND Combine Multiple VCD DAT files to Single Divx/Xvid file
By GrayStrickland in forum Video ConversionReplies: 4Last Post: 17th Aug 2012, 12:23 -
Convert A DivX with AC3 To VCD
By Stinky in forum User guidesReplies: 43Last Post: 23rd Jul 2011, 03:55 -
how to correct out of sync video/audio in mkv file
By 55trucker in forum Video ConversionReplies: 37Last Post: 22nd Mar 2011, 11:08 -
Convert X to DVD - preview videos show not correct video
By mirage0101 in forum Authoring (DVD)Replies: 3Last Post: 6th Sep 2010, 02:05 -
Convert divx vbr to cbr audio - video freezes (possible reason & soluti
By lingyi in forum AudioReplies: 0Last Post: 4th Oct 2007, 15:51
