  1. At the risk of getting shouted at, does anyone have a definitive guide
    to avoiding a video track skipping on past audio ?
    I use TMPGenc to convert DIVX to VCD, the quality is excellent, with
    the exception of intermittent skips and jumps in video.
    I have read many posts, both here and on TMPGenc, however a
    definitive guide would benefit everybody. It also could be
    part of the VCDHelp website !
    Many thanks to any contributors.
    Canada
    I suspect it's impossible
  3. So you're basically saying you're having audio/video sync problems?
    There are many, many relevant posts on the topic.
    gateway to the west
    you aren't converting between formats, like ntsc to pal or vice versa are you? Also it could be the divx codec or the priority placed on it.
    From what I take of your comment, its not a video/audio sync problem, but that your picture basically flutters. Though its hard to say why, mainly because you really didn't describe anything about what you were doing, settings etc.
    ttfn,
    cbj
