You're talking about line level outputs? What connectors? For 3.5mm stereo pin plug as is used for most computer speakers, something like this A/B switch:
https://www.amazon.com/STEREO-Manual-Speaker-selector-available/dp/B073GWCRP3/
For RCA connectors:
https://www.amazon.com/Duttek-Switcher-Composite-Component-Consolesav/dp/B0753CQ668/
The latter also switches composite video (yellow connectors) but you can just ignore that.
Results 31 to 33 of 33
Hey,
Yeah sorry for not mentioning it, i got 2x 3.5 aux cables that i would like to run on the speaker and asked if its enough to get a simple y 3.5 splitter. I want them both to be connected at the same time but only use one input at a time.
Thanks for the suggestion, so i would defentley need to run some sort of mixer for this ? -
The devices I recommended are just passive A/B switches. Essentially the same as disconnecting one cable from the speaker and attaching the other -- just easier. Using an A/B switch is much safer (for the devices) than using a Y adapter cable. You shouldn't feed the output of one device into the output of another device (the signals don't know which way to go through the Y splitter -- they go both ways) -- though you can probably get away with it.
An active mixer is the safest of all and will let you adjust levels (in case one device is louder than the other). A mixer will present the correct levels and loads on each input and output.
2.1 speakers configuration under Windows 7
By kyrcy in forum ComputerReplies: 35Last Post: 15th Jan 2018, 04:07 -
5.1 audio on 2 speakers PC
By Freodon in forum AudioReplies: 3Last Post: 10th Dec 2015, 19:27 -
PC speakers & TV Speakers At The Same Time
By TheRandomOne in forum AudioReplies: 0Last Post: 6th Oct 2015, 12:20 -
suggest better speakers for video editing?
By sdsumike619 in forum AudioReplies: 11Last Post: 23rd Jan 2015, 18:26 -
Bluetooth desktop speakers
By carlos28355 in forum ComputerReplies: 0Last Post: 7th Feb 2014, 22:04
