Hi,
I'd like to try learning to do some basic video editing, to be able to mix in shots from different vids and from different sections in the same vid and shorten things etc. Also to be able to add sounds and music. And as you can tell I'm not only very new to it but haven't even tried doing any yet. At this point I'm trying to find the best free or cheap editor to use, so would like one that's fairly easy to learn and also that's popular enough I can ask for help in forums. Maybe even some of them have their own forums? I found that to be true and a great forum it is for Reaper DAW for example. Right now from a review I read and then some Youtube tutorials I'm thinking hard about trying Openshot. Would that be as good to start out with as any?
Thank you for any help or suggestions!
David
If you want to start learning in this area and to make money, go for Blackmagic Davinci, you won't regret it. Once you master it, you won't even need to go to work anymore, build a home office and work there. If you think it's hard, try to do some training.
Nvidia deep learning AI improvement in Slowmotion videos and denoising
By Bernix in forum Latest Video NewsReplies: 2Last Post: 27th May 2019, 19:28 -
Beginner - Learning which codec is best - and where to get them.
By CodecConfused in forum Video ConversionReplies: 5Last Post: 3rd Aug 2017, 19:20 -
Need help learning how to pull out stream links to create a .strm file
By cnmsales in forum Video Streaming DownloadingReplies: 0Last Post: 22nd Apr 2014, 01:46 -
Learning about running video for live concerts
By Paul999 in forum Newbie / General discussionsReplies: 0Last Post: 21st Apr 2014, 10:06 -
vhs/hi8 search terms for learning
By dianedebuda in forum Newbie / General discussionsReplies: 11Last Post: 22nd Jan 2014, 00:08
