What do all you experienced users recommend for a chubby, retired, old guy in Omaha just wanting to do some very basic video editing?I don't need a $600 Sony Vegas Pro or Adobe Premier. If my needs advance as my experience does, I will never need these.
For now I am joining a couple, or few, videos per week of my playing guitar with the occasional transition just to make them smoother. And then I post them on a website for my guitar instructor to criticize. His critiques are usually very brutal, btw. Soon, I will record the audio of my playing into a digital audio workstation to obtain a better sound quality. I will then replace the audio on the video with that.
I will, I'm sure, start doing some recording and editing of grandkids' videos, our horses, trips, a cruise in a couple months, etc. But just fun stuff. Never anything professional or demanding.
I have narrowed it down to these three (OpenShot, VideoPad and VSDC), for the blatantly obvious reason of FREE. And I'm sure anyone of these for my basic needs will serve. But I don't want to invest a lot of time in learning one to find something down the road I should have known about.
And while these are attractive for their cost I'm not completely opposed to investing a few bucks if there is one that is significantly better for my needs as I have tried to describe them.
Thanks for your suggestions.
Results 1 to 11 of 11
You can get Vegas pro 15 for 25$ from https://www.humblebundle.com/software/vegas-pro-even-more-software
True. Vegas Movie Studio 15 Platinum is on still sale for $49.99 as a download from vegascreativesoftware.com. https://www.vegascreativesoftware.com/index.php?gclid=EAIaIQobChMIv9_Zruqp3wIVwR6GCh3D...PtCllArZvjlyXI
I have seen several members recommend it as very capable entry-level software. There is a free trial. https://www.vegascreativesoftware.com/us/vegas-movie-studio-platinum/Ignore list: hello_hello, tried, TechLord, Snoopy329 -
VSDC, probably, won’t seem intuitive at first sight, but it’s quite easy to learn. There is also a YouTube channel with detailed videos on how to work with the software - https://www.youtube.com/user/FlashIntegro/videos. Free version consists of all basic operations, plenty of effects, Audio Gate and Median filters for working with audio.
You guess incorrectly then.
I have never heard of Avidemux. I doubt if I will try it though because I don't think I can pronounce it
I did try it. There was nothing, as I recall, that just jumped out as hugely negative. It wasn't a steep learning curve or horrible interface. I just didn't bond with it.
Thanks, guys. -
All this time trying the free ones and I ended up going with Vegas Movie Studio Platinum. I think it cost me $50? I tried the ones I originally asked about and they were either buggy or had no support. All the time spent trying the others I could just about be an expert in Vegas by now. Oh Well. I bought it and I'm not looking back.
Help with Openshot...
By quetzalin in forum Newbie / General discussionsReplies: 1Last Post: 2nd May 2018, 16:09 -
Urgent Question about Videopad!
By Rusakov in forum EditingReplies: 18Last Post: 8th Aug 2016, 18:14 -
Audio Scrubbing for VideoPad
By Aloysius1948 in forum Newbie / General discussionsReplies: 2Last Post: 28th Apr 2015, 08:39 -
Uninstalling VideoPad
By zookywii in forum EditingReplies: 1Last Post: 24th Jun 2014, 11:49 -
Videopad new line problem
By antagonist in forum SubtitleReplies: 3Last Post: 31st May 2014, 22:51
