Ok here it is, increasingly over the last few months I have been getting downloads that I have not been able to play on media player,real one and divx playr. I have deleated them thinking they were bad files. However it has reached a point where almost everything I download now will not play on any of my 4 players. I have even tried to load them into Tempg. and Vitual Dub they also tells me it is not supported. All my players are updated, and they all work. Real player normally will tell you what codec you need but it hasn't been and media player will will try to find the codec but it hasn't. I just have reached the end of ideals. Any suggestions?
I had better add I am running windows 98 and the files I've downloaded were mpg 1 and avi's.
First thing is i would get divx 5.0.1 codec if you don't have it, and you could also try to use divxfix on them.
you can download divx 5.0.1 @ http://download.com.com/3000-2194-9675928.html?tag=lst-0-1
and you can download divxfix @ http://www.divx-digest.com/software/divfix.htmlI went to look for myself, if I get back before I return, Keep me here. -
I have nimo codec pack but I thought that was just for tmpg. Please explane. thanks
Find the MPEG-4 V3 codec. It seems to make up alot of the movies I download. I too thought they were divx. But when I reinstalled my OS, I just reinstalled the divx 5 codec and found myself unable to play the movies at all, no decompressor found. I found out the movies were MPEG-4 V3 codec files, not divx. So try that out to, find the Krystal Codec Pack, that how I got mine, anf there are lots of other packs out there. Just look for MPEG4 codecs. Your movies are wither divx or mpeg4 files.
The once again new Ebay policy changes to hurt sellers even more.
By MeDiCo_BrUjO in forum Off topicReplies: 18Last Post: 19th Dec 2013, 21:58 -
Does rendering to same format hurt quality?
By R Man in forum Video ConversionReplies: 8Last Post: 22nd Nov 2011, 19:14 -
Any Retail/ Brick & Mortar Stores that sell DVD cases?
By slayerbizkit in forum MediaReplies: 3Last Post: 25th May 2011, 22:38 -
Something to hurt your brain
By guns1inger in forum Off topicReplies: 12Last Post: 22nd Aug 2008, 17:04 -
Holiday sounds coming from the walls..
By vhelp in forum Newbie / General discussionsReplies: 4Last Post: 28th Dec 2007, 23:20
get nimo codec pack
