Hi,
I got a avi to burn but the file is 716 mg large.
I own a plextor 16x
do I have to make an overburn.
any help is appreciate
Vracky
http://www.pricewatch.com lists some cdrs that are 730 mb in capacity.
there might be some larger discs available at a compusa if you have one near you.
yo
THIS IS HARDCORE -
Thanks for the info.
anyother trick?
I also own premiere...Can semeone could explaine me how to reduce the file off about 20 mg? -
Cut out some of the intro or end credits in the video with VirtualDub. If you cut by the keyframes, you will have no problem. I've cut down large AVIs by this method...it's great!
Make sure you set Audio>Direct Stream Copy, Video>Direct Stream Copy.
Or you could re-encode the audio (it's probably MP3) with a lower bitrate, if it's not already the lowest. This could save a couple of MBs.
Tom Green Sucks! -
I agree with the first post if you can't cut off the credits order some 90 min or 800 mb cd's if you can afford the plextor you can afford 90 min disks
Have fun -
are there any external firewire drives that supports Nero overburn? i saw a QPS drive listed on the Nero site but the model # doesnt match the list of drives shown in the qps's website.
if you're burning a VCD/SVCD a 716 MB file will fit on a 74 minute disc. it will definitely fit on an 80 minute disc. no need for overburning at all. VCD/SVCD/AudioCD use Mode 2, which saves the bytes normally used for error correction of data files and uses them to put more a/v on the disc.
one easy way to chop file size a few MB is to demux the audio, re-encode it at a slighly lower bitrate, and then remux it back together with the original video. you could easily cut more than 20 megs with minimal quality loss if you're burning an AVI to a data CD.
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 13:42 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 05:26 -
Advice required when trying to burn with img burn
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 1st Aug 2009, 17:29 -
Plextor PX 716 problems
By cajmere in forum DVD & Blu-ray WritersReplies: 11Last Post: 31st Dec 2007, 06:37 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 21:46
