I have an MGEG-2 file (NTSC) and tried to burn an SVCD using VCDEasy (VCDImager/CDRDAO). The resulting CD was not playable in PowerDVD4.0 ("Error Code 89030000" - Unknown file format"). But PowerDVD was able to play the original mpg file from disk!
After many searching and trying I downloaded a test version of Nero - and the CD burned with Nero was playable in PowerDVD4.0! I also asked a friend to test my CD's with his WinDVD - and here both(!) CD's worked.
I also downloaded the test svcd image from vcdhelp, it was playable with PowerDVD without any problems.
I don't want to buy Nero or WinDVD, I'm still hoping that I can use VCDEasy and PowerDVD.
Any ideas?
TIA!
Matti
P.S.:
If somebody can handle it, here's the XML content for my SVCD as generated by VCDEasy:
<?xml version="1.0"?>
<!DOCTYPE videocd PUBLIC "-//GNU//DTD VideoCD//EN" "http://www.gnu.org/software/vcdimager/videocd.dtd">
<videocd xmlns="http://www.gnu.org/software/vcdimager/1.0/" class="svcd" version="1.0">
<option name="relaxed aps" value="false"/>
<info>
<album-id></album-id>
<volume-count>1</volume-count>
<volume-number>1</volume-number>
<restriction>0</restriction>
</info>
<pvd>
<volume-id>SUPER_VIDEOCD</volume-id>
<system-id>CD-RTOS CD-BRIDGE</system-id>
<application-id></application-id>
<preparer-id/>
<publisher-id>VCDEASY_V108</publisher-id>
</pvd>
<filesystem>
<folder>
<name>SEGMENT</name>
</folder>
</filesystem>
<sequence-items>
<sequence-item src="F:\Movies\MyMovie.mpg" id="Sequence-01-01">
<default-entry id="Chapter-01-01"/>
</sequence-item>
</sequence-items>
</videocd>
Results 1 to 1 of 1
Why does one dvd made with ConvertXtoDVD play and another doesn't?
By Hal05154 in forum Authoring (DVD)Replies: 6Last Post: 25th Mar 2011, 23:29 -
Can't play audio from avi made from mkvtovob for ps3
By User81 in forum AudioReplies: 1Last Post: 25th Feb 2011, 03:45 -
Can't play PCM audio from MPEG made from MKV
By brianp6621 in forum AudioReplies: 10Last Post: 19th Oct 2009, 12:12 -
DVD Made on Your Recorder Play on Another Brand?
By retexan599 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 19th Jun 2008, 12:12 -
home made DVDs wont play on all stand alone DVD players. why?
By suomiaussie in forum Authoring (DVD)Replies: 12Last Post: 2nd Jan 2008, 20:59
