There's no definitive answer to that question. You would have to look for something of known aspect ratio in the video and measure it. But the reality is, you will rarely notice either way.
Results 91 to 96 of 96
Thanks, I'll have a look to see if I can find something that helps me compare, but as you say it would rarely be noticeable anyway.
I do have another problem with one of these DVDs. The MKV file I created is listed as Interlaced, as are the rest of the DVDs, but this one clearly isn't. No signs of interlacing artifacts, and as I didn't realize it until it was too late, my QTGMC output is, as one would expect, duplicating each frame. Some apparent bobbing in the original DVD makes me suspect this could have originated from an interlaced source, but I don't know. I'll make a sample later when I'm able if it helps, just let me know. I don't expect to make the original video 'better', my main reason for converting these DVDs was to get rid of the interlaced source. In this case, the video is listed as interlaced but doesn't look to be. Should I try converting it to progressive somehow? Could it be just badly reported? This is the MediaInfo for the file I extracted with MakeMKV:
Code:General Unique ID : 20167917111741278134833159412687806590 (0xF2C33159648D6D1EA1420148F9FA07E) Complete name : C:\Videos\14\title_t00.mkv Format : Matroska Format version : Version 2 File size : 3.61 GiB Duration : 2 h 49 min Overall bit rate mode : Variable Overall bit rate : 3 049 kb/s Encoded date : UTC 2019-02-11 05:59:27 Writing application : MakeMKV v1.14.2 win(x64-release) Writing library : libmakemkv v1.14.2 (1.3.5/1.4.7) win(x64-release) Video ID : 1 ID in the original source medium : 224 (0xE0) Format : MPEG Video Format version : Version 2 Format profile : Main@Main Format settings : CustomMatrix / BVOP Format settings, BVOP : Yes Format settings, Matrix : Custom Format settings, GOP : M=3, N=12 Format settings, picture structure : Frame Codec ID : V_MPEG2 Codec ID/Info : MPEG 1 or 2 Video Duration : 2 h 49 min Bit rate mode : Variable Bit rate : 2 852 kb/s Maximum bit rate : 8 671 kb/s Width : 720 pixels Height : 576 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 25.000 FPS Standard : PAL Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First Compression mode : Lossy Bits/(Pixel*Frame) : 0.275 Time code of first frame : 00:00:00:00 Time code source : Group of pictures header GOP, Open/Closed : Open GOP, Open/Closed of first frame : Closed Stream size : 3.38 GiB (94%) Language : English Default : No Forced : No Original source medium : DVD-Video Audio ID : 2 ID in the original source medium : 189 (0xBD)128 (0x80) Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 2 h 49 min Bit rate mode : Constant Bit rate : 192 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Bit depth : 16 bits Compression mode : Lossy Stream size : 233 MiB (6%) Title : Stereo Language : English Service kind : Complete Main Default : Yes Forced : No Original source medium : DVD-Video Menu 00:00:00.000 : en:Chapter 01 00:06:57.560 : en:Chapter 02 00:32:11.800 : en:Chapter 03 00:48:26.800 : en:Chapter 04 01:02:16.720 : en:Chapter 05 01:33:28.400 : en:Chapter 06 01:51:50.800 : en:Chapter 07 02:14:30.080 : en:Chapter 08
Almost all PAL DVDs are encoded as interlaced. That's what you're being shown - how it was encoded. It says nothing about the actual content of the video. There's a big difference. If, when looking at the frames, you don't see interlacing, it's not interlaced and it can be treated as progressive. In any event, there's no need for QTGMC when working with a progressive source.
The MKV file I created...
Some apparent bobbing in the original DVD makes me suspect this could have originated from an interlaced source... -
Yeah, the reason I didn't notice before running QTGMC was that I was leaving my PC for a long while and figured it would be good to leave it encoding something, so (having so far had only interlaced material) I was careless and didn't check before.
Why not use DGIndex on it to create a D2V project file followed by using MPEG2Source to open the video for examination?
If it's a movie, by definition it's progressive, although DVD makers have ways to screw that up so it appears to be interlaced.
So, from what you said, I guess I don't have to do anything with this file, i.e. it being encoded as interlaced should not be a problem, right? -
That's right, assuming it really is as you say, that its content is progressive. That assumes you're testing with something that's not deinterlacing on the fly. I open my DVD sources in VDub (using MPEG2Source on them) to examine the frames and perhaps the bobbed fields to check how the DVD should be handled. I'm in NTSC land, but the process is the same.
I wouldn't really know much what to examine on the source... -
Since I started dealing with these interlaced videos, I disabled the Deinterlace option in my go-to player (it used to be set to Auto) so I notice right away (I just never got to play this one before I ran QTGMC on it).
I don't use it, but I assume StaxRip makes the AVS script available to you. You can comment out any filtering such as QTGMC and open that script in VDub to examine the unfiltered frames.
Hi ! Newbie Here, keen to learn
By JayStew in forum Newbie / General discussionsReplies: 0Last Post: 30th Jan 2018, 02:49 -
Restoration workflow and some questions for a newbie willing to learn.
By Dannyboy1985 in forum RestorationReplies: 2Last Post: 30th May 2017, 15:27 -
Newbie looking to learn how to use Leawo blu ray copy AND Blue Cloner 5
By joer0194 in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2015, 02:13 -
Need suggestions to change Aspect Ratio on DVDs
By elviszappa in forum EditingReplies: 4Last Post: 2nd Oct 2014, 20:43 -
Ripping NTSC DVDs for Australia newbie questions
By pcwizard7 in forum DVD RippingReplies: 11Last Post: 11th Sep 2014, 09:58
