Hello
I would like to ask about some help with a problem im having.
I cant find a way to Embedd / Hardcode subs in a mkv movie.
I have tried handbrake BUT then i have to Transcode the movie and i DONT want that.
I like the video to be be untouched.
Does anybody know a way to do this?
Thanks alot for any help.
Results 1 to 10 of 10
Hardcoding requires a reencode and degradation of the video. You don't want that. You don't want to use Handbrake at all. To embed subs use the MKVMerge portion of MKVToolNix.
Assuming you have the latest version of MKVToolNix when you run it that is the program you need. The actual mkvmerge is mkvtoolnix-gui.exe or the command line version mkvmerge.exe
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Ok but i cant find a way to enmbedd subs, there is an forced option but that wont "burn" the subs in the movie
To clarify i DONT want to add a sub file i want to "burn" the forced subs so they allways show in any player.
OK thanks for the help, i thought maybe its possible to keep the same bitrate and "burn" subs into a movie
Burning in means altering the video so that the subs become part of the video so re-encoding will take place. If you add the subs to the MKV and marked them as default and forced most media players that will handle MKV file should show the subs but of course there is always the exception...
Taking subs from mkv A and B to replace subs from mkv C in a different lang
By Boxgoblin in forum SubtitleReplies: 2Last Post: 26th Nov 2017, 12:00 -
How to protect subs in mkv from extraction/demuxing
By ZloyZloy in forum SubtitleReplies: 10Last Post: 29th Aug 2017, 00:41 -
MKV not displaying embedded subtitle PLEASE HELP
By maverickluke in forum SubtitleReplies: 1Last Post: 27th Mar 2017, 11:21 -
Virtualdub forward mkv subs into avi?
By Anvil2k12 in forum SubtitleReplies: 3Last Post: 6th Jul 2016, 09:57 -
How to cut mkv files WITH subs?
By shernoam in forum EditingReplies: 38Last Post: 14th Aug 2014, 14:37
