Guys what about a usbc to dvid at 2560x1600. USbc has power and data so i would imagine this would be ideal. I plan to upgrade to a dell 9570 soon that is full with usbc ports
Results 31 to 38 of 38
The Dell XPS 15 9570 has a Thunderbolt™ 3 port with a USB C interface, and this Thunderbolt 3 port is able to supply native DisplayPort 1.2 video output. You would need a USB C Displayport to Displayport adapter plus a DisplayPort to Dual-link DVI-D adapter.
Example of a USB C Displayport to Displayport adapter:
https://www.amazon.com/Doitby-USB-Displayport-DisplayPort-Type/dp/B07DN4G5ST/
Also, do not buy the Visiontek adapter from Dell in pandy's link below.
According to Visontek that adapter only supports up to 2650x1440. See https://www.visiontek.com/mini-displayport-to-dual-link-dvi-d-active-adapter-m-f.htmlIgnore list: hello_hello, tried, TechLord, Snoopy329 -
Instead of going usbc to displayport and then displayport to dvid, why not go directly usbc dvid if there is such a cable
What you would actually need is an external graphics adapter with a USB 3.1 Gen 2 USB type C interface if you want to avoid using DisplayPort and use USB instead. I don't know if any exist with dual-link DVI-D support.
[Edit]Thunderbolt 3 would be another option, but I don't know if there is an external graphics adapter with a Thunderbolt 3 USB type C interface and dual-link DVI-D out.
[Edit 2] Your 10-year-old formerly cutting-edge expensive monitor has become a white elephant in 2018. white elephant = a possession entailing expense which is out of proportion to its usefulness.Last edited by usually_quiet; 24th Dec 2018 at 12:25.
I looked for an external graphics adapter with a USB 3.1 or USB 3.0 connection to the source PC and dual-link DVI-D out but had no luck. Every adapter that I found with DVI-D out had single-link DVI-D not dual-link DVI-D. I didn't find any Thunderbolt 3 to dual-link DVI-D adapters either.
However, the Dell XPS 15 9570's Thunderbolt 3 connection can supply 4 lanes of PCI Express Gen 3 and power. This allows the use of a eGFX enclosure, in which a desktop graphics card would be installed. eGFX is not inexpensive, and the graphics card is a separate purchase. The only "good news"for this solution is that since the graphics card can use only 4 lanes, it would make no sense to buy a high-end card.
A DisplayPort to dual-link DVI-D adapter capable of supplying 2560 x 1600 plus a USB-C DisplayPort to DisplayPort adapter would still be less expensive.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Guys lets make one last attempt. My 9570 is here. I intend to get a usbc hub, so i can connect monitor and usb periphals in one swoop when i go to the office, instead of having to connect 4-5 cables one by one each morning.
So is there at least a usbc hub, that offers a dual dvid capable at this resolution? Since i will be getting such a hub, if there is i wont be considering this a single purpose expense, like getting this displayport active adapter is now
If not i give up, i'll resurrect an older desktop and upgrade some of each parts and use this monitor for 2k gaming -
You answered my post by repeating post #2 from pandy without attribution. That kind of reply is usually generated by bots or posted by spammers. If you are neither of those things, therock003's 10-year-old monitor probably does not support input at 24Hz. The specs I found for that monitor don't list any vertical refresh rates other than 60Hz. Plus, monitors from 2008 or 2009 were often limited to vertical refresh rates between 50Hz and 75Hz, and possibly to just 60Hz.
Also, read posts 28 - 30 to find out the other reason why the option of using pandy's solution isn't always available using HDMI 1.4 as the source.Ignore list: hello_hello, tried, TechLord, Snoopy329
the capture card vendor's S-VIDEO adapter DVI HDMI problem
By 280634157 in forum Capturing and VCRReplies: 2Last Post: 12th May 2018, 18:53 -
The best HDMI to component adapter
By mol3000 in forum Newbie / General discussionsReplies: 5Last Post: 15th Jan 2017, 16:59 -
Tablet HDMI out to VGA/DVI of old 17" monitor
By tector in forum Newbie / General discussionsReplies: 2Last Post: 6th Nov 2015, 08:11 -
Is it possible to detect that any HDMI/DVI video grabber is attached?
By eiger5678 in forum Capturing and VCRReplies: 5Last Post: 27th Sep 2015, 16:02 -
HDMI changes DVI resolution
By Lamanator in forum DVB / IPTVReplies: 7Last Post: 22nd Mar 2015, 11:26
