I recently bought a 'MICCA Spec 1 G2 media player. I doesent play *.iso's, but will (it sez) MKV files. I have mostly movies saved to iso images, all with subtitles, (<- this is important!), and would like to convert (some of) them to MKV. Some are movie only & some are full disk rips. Which converter would be the best for me? Preferably free!
This Micca is much better than my WD TV303D which has been back in its box for a few years. About equal to my Dune player, which the Dune has a swappable 2.5 hdd tray. I still prefer my Argosy player but this Micca is sooo small its perfect for a portable player. (I can put the player, remote, 5v psu, all cables, & a usb 2.5 hdd in one "cargo pants" pocket.
Anyways, can I get suggestions?
(In the software section, I couldnt figure out any which would 'fill the bill' for me)
-corne-
	Yes, no, maybe, I don't know, Can you repeat the question?
	SaurusX:
 Thanks!!
 I tried this : mkvtoolnix-64-bit-28.2.0.7z inc newer & older & 32bit & 64 bit. No instructions at all, (that I could find), installed but NO help
 I shoulda mentioned this in 1st post.
 I will try MakeMKV, , , , ,Last edited by cornemuse; 10th Dec 2018 at 16:22. Reason: feng shui Yes, no, maybe, I don't know, Can you repeat the question?
	MakeMKV is great, but understand that you'll lose the menus on the full DVDs and each video (e.g. extras, or individual episodes) will be a separate file.
 You might try extracting the VIDEO_TS file and click on the .ifo file access the menu and videos. It's possible it may work, but unikely.
 Interesting that the Spec doesn't support .iso. If it continues to be an issue, Micca's MPlay-HD lists playing DVD and Blu-Ray .iso as a feature. There are some apps that claim to be able to play .iso on Android, but I haven't come across anything that works well.
	The 'MakeMKV' works ok. 'Nother thing, the Spec claims to play dvd folders, but apparently not movie dvd folders. However, it will play DVD's with a usb cdrom unit. (claimed in specs, have not tried this yet) Yes, no, maybe, I don't know, Can you repeat the question?
  Extract/convert/ripp/copy u name it 3D blueray iso to mkv sbsBy dannydevito in forum Blu-ray RippingReplies: 0Last Post: 19th Jan 2016, 04:47
  Convert 3D BD .iso to .mkvBy AK 47 in forum Blu-ray RippingReplies: 15Last Post: 20th Jun 2015, 19:09
  Anyone know how to convert mkv to mp4 & KEEP subtitles?By distinctive2004 in forum Video ConversionReplies: 4Last Post: 13th Jun 2015, 19:43
  Best free mkv with 2 audio tracks to .iso or Video_TSBy djdan in forum Authoring (DVD)Replies: 2Last Post: 1st Jun 2015, 08:38
  Convert ISO files to mkv with menu and extraBy angiotell in forum Video ConversionReplies: 3Last Post: 26th Jan 2015, 06:23
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
