I need your help again. How do I change the frame rate of this video to 29.970 (30000/1001) FPS. The video doesn't have any interlace/combing artifacts. When I encoded it the first time I got duplicated frames (59.940 FPS) and when I used ChangeFPS(29.970) I got 29.970 (29970/1000) FPS which is not what I want. Thank you
Code:Video ID : 2 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings : CABAC / 2 Ref Frames Format settings, CABAC : Yes Format settings, RefFrames : 2 frames Codec ID : V_MPEG4/ISO/AVC Duration : 1 min 32 s Bit rate mode : Variable Bit rate : 34.0 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Variable Frame rate : 59.940 (59940/1000) FPS Original frame rate : 29.970 (30000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan type, store method : Separated fields Scan order : Top Field First Bits/(Pixel*Frame) : 0.274 Stream size : 373 MiB (98%) Default : No Forced : No
ChangeFPS(30000, 1001)
However, if this video is film-based that would be incorrect. After the ChangeFPS call, check for duplicate frames again.
Edit later:
Or SelectEven or SelectOdd. Same result.Last edited by manono; 9th Dec 2018 at 16:40.
What is the proper way to deinterlace? Source: FPS is 29.970 interlaced.
By strawberryshortcake in forum RestorationReplies: 41Last Post: 1st May 2018, 11:49 -
How to convert 4k 60 FPS to real 1080i (29.970)with Avisynth?
By frank_zappa in forum Video ConversionReplies: 12Last Post: 11th Nov 2017, 11:08 -
Convert 51.43 fps video in 59.94 fps container to straight 50 fps video
By mr_lou in forum Video ConversionReplies: 5Last Post: 8th May 2016, 12:47 -
Help me with this 1080i MBAFF 29.970 fps file.
By protoX in forum EditingReplies: 2Last Post: 25th Nov 2014, 04:46 -
frame rate reduction of 29.970 fps to 23.976 fps in megui
By yohanfed in forum Video ConversionReplies: 2Last Post: 28th Jun 2014, 20:15
