First time using this program. I downloaded TMPGEnc beta 12i and VFAPI plug-in and unzipped/ran install.bat according to instructions. When I added a video source (DV-AVI) I get some God-awfull error and my machine locks up. I deleted the folder and unzipped again-same issue.
The AVI is a file I exported out of Premiere. Is this a problem with the AVI or with this beta version or another issue I am missing?
Thanks in advance.
Results 1 to 9 of 9
Premiere-exported-avi's have problems opening in TMPGEnc.
Change the AVI priority (to something higher) in the environmental settings and that should fix it.
AP Enterprises Ltd. -
Ok, changed the AVI priority around (higher) and it still crashes as soon as I try to load the AVI.
If I'm screwed, what is the next best answer to converting my AVI's to VCD, SVCD, DVD, ect.? -
use Panasonic, it's much more stable than TMPGEnc and less blocky since it makes a smoother image. But it does take a lot longer to encode, but it does do DivX really well
you could also try loading the avi into virtualdub, then frameserving to tmpgenc.
On 2001-07-31 11:01:56, AP Enterprises Ltd wrote:
What is the VFAPI plugin for, anyway? What does it do?
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
here is a write up on vfapi... -
oh. thanks.
And one more question:
Can I use a DV-codec-compressed MPG file as the input file in TMPGEnc or does it have to be uncompressed AVI? Cuz if it has to be uncompressed AVI, then ouch, I need a bigger HD.
Two questions actually...:
What is the difference between DV-type 1 compression and DV-type 2? What should I use?
AP Enterprises Ltd.
HC enc: Your settings ?
By themaster1 in forum RestorationReplies: 6Last Post: 21st Oct 2011, 20:55 -
ENC encoding versus no ENC encoding
By RL in forum ffmpegX general discussionReplies: 3Last Post: 4th Feb 2011, 18:44 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 17:02 -
New Kiss DejaVu Enc released
By slmnow in forum Latest Video NewsReplies: 0Last Post: 20th May 2008, 12:08 -
Something better Tmpeg Enc
By 02fx4dude in forum Video ConversionReplies: 4Last Post: 15th Aug 2007, 07:23
