I'm looking for a way to change the container for MKV, FLV, and AVI video to MP4 (without re-encoding), since none of the aforementioned 3 are compatible with Smart Cutter (whereas MP4 is).
FFmpeg can be used to remux these containers to mp4 assuming the audio&video formats used in those containers are mp4 compatible.
Cu SelurCode:./ffmpeg -i <path to input file> -codec copy <path to output file with .mp4 extension>
users currently on my ignore list: deadrats, Stears555, marcorocchini -
Compatibility is the iusue here, isn't it? .mp4 is just a container, not a format. For example there's a list of smart cutter compatible opfrmats here and I don;t see the type of format you;d see in .avi files (ASP) there:
http://www.fame-ring.com/smart_cutter.html -
Well, the format for the AVI container files is H.264, AAC (same with the MKV and FLV).
Brorsoft Video Converter, yes I know, I had to spend about $30 but it really does a great job Remuxing and batch processing. I don't think they have it for Mac though... I can't remember which one I use on Mac but if I remember I will come back and edit it in. (Here is an edit it in remembrance) I used to use "Remux" on the Mac and I see that it is still out there albeit it is a newer version. I haven't figured out how to do multiple folders and have it recreate the separate multiple folders on the output though. It just takes everything from any nested folders and remuxes them into one folder. I prefer Handbrake if you actually have to transcode and still want quality but Brorsoft is quick and processes 4 at a time. I can't say enough about Handbrake because it makes the best compatible and quality transcodes and does a great job on batch processing but is no where near as fast as remuxing.
Oh yes I have also used MPEG StreamClip http://www.squared5.com/ as it can remux and works on Mac but I don't think it is as compatible or fast like Handbrake or Brorsoft.
One cool thing about MPEG Stream Clip is that it can actually fix a bad video timeline which has broken time code and would otherwise drop all video after the time code break but Streamclip will rebuild all time code breaks so those programs that error out on some videos Streamclip can fix it.Last edited by Illusion; 18th Apr 2019 at 21:49. Reason: Added a sentence and link to the software I use for batch remuxing
Best Program for MKV to MP4 Conversion -- NO quality loss?
By xxevilxp3nrxx in forum Video ConversionReplies: 13Last Post: 13th Aug 2015, 03:47 -
flv to avi/mp4 conversion
By rocketman778 in forum Video ConversionReplies: 7Last Post: 18th Apr 2015, 15:47 -
Free tools on Mac: Remux BDMV folder into mp4/mkv?
By TOMillr in forum Video ConversionReplies: 5Last Post: 18th Apr 2015, 06:45 -
Multi bluray to mkv remux batch program
By Freak1 in forum Blu-ray RippingReplies: 6Last Post: 8th Dec 2014, 04:20 -
How do you remux aac and ac3 from mkv to mp4? winff won't keep both
By yoda313 in forum Video ConversionReplies: 4Last Post: 11th Jan 2014, 20:00
