HI, I successfully copied one of my dvds last night, and it came out
perfect the picture quality was amazing, I never thought it would be so good!
I do have a couple of questions though..
1] The movie I copied was anamorphic widescreen(PAL), so what settings for
aspect ratio should I choose in TMPGEng? I choose 16:9, I want to keep the black bars for widescreen, the picture was ok, with black bars, but I may have noticed a very slight vertical stretch?
2] Also, my dvd-rom is firmware locked, does this mean I cannot copy Region 1 dvd's?
Using smartripper trying to rip my region 1 copy of three kings it said
"Some files are still locked!
Try to unlock with a player! "
Anyone able to help me out on either of these?
sterankin, dvd2avi's info box will tell you the source aspect ratio (either 16:9 or 4:3)..this is wut u enter into tmpgenc
as for ripping region 1, did you play 3 kings w/ winDVD/powerDVD first? you need to do that first.... -
you'll have to change the region settings for your dvd-rom to rip it. or atleast to unlock the dvd with Windvd/powerdvd.
now moast roms can be changed a few times and then it locks.
if your going to keep backuping dvds from diffrent regions you might want to make the rom region free.
Sears google for region free firmware for your dvd-rom.
This is a bit risky (a friend f**ked his drive up), but if done right there should be no porb.Well, I am the slime from your video.
Oozin' along on your livin'room floor.
DVDFab Blu-ray Copy vs. DVD Copy
By coody in forum Blu-ray RippingReplies: 1Last Post: 11th Oct 2010, 12:33 -
How do i copy dvds onto hard drive and what is best software to copy sav
By bfishwick in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2009, 17:29 -
Copy of a Copy of a Protected VHS Tape to DVD
By solarblast in forum DVD & Blu-ray RecordersReplies: 12Last Post: 18th Dec 2008, 07:36 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 07:26 -
cannot copy 22.5 Gbyte file with Win XP copy command
By maxtrack in forum Newbie / General discussionsReplies: 7Last Post: 2nd Aug 2007, 14:12
