I want to put a picture at the end of the video for 30 seconds. How can I do this?
What software are you using to create your video? Usually you import a photo and add it to the end of your timeline of your video. Any decent video editing software can do that.
Extraordinary claims require extraordinary evidence -Carl Sagan -
MeGUI uses AVISynth, right? And you can edit the AVISynth script it creates, right? If so, then here's one way to do it. First, create a BMP picture at the same resolution as the video. I call it Picture.bmp. Call it anything you like, but change the script to match.
Second, create a new AviSynth script (an AVS I call Picture.avs) with this inside it:
ImageSource("Picture.bmp",Start=0,End=749,FPS=25)
ConvertToYV12()
After doing that, open Picture.avs in VDub to make sure it works. The resolution should be the same as the video it'll join, same framerate, 30 seconds long. Your original video is most likely YV12, but if it isn't make sure both are in the same colorspace using the right ConvertTo... command.
Then edit the script MeGUI gave you. Below the last line stick this:
Picture=Import("Picture.avs")
Last+Picture
Save it and open that in VDub and test it to make sure it's as you want it. If there's an error message, post the complete script along with the error message.
convert mp3 to mp4 and add picture
By kasfig in forum AudioReplies: 8Last Post: 14th Oct 2017, 23:47 -
How to add blankclip onto end of video?
By VideoFanatic in forum RestorationReplies: 4Last Post: 22nd Jan 2016, 14:12 -
Can someone add batch encoding to this x265 ffmp front end (written in ahk)
By ezcapper in forum Video ConversionReplies: 0Last Post: 5th Jul 2015, 15:13 -
Needs some freeware HD video editor/s which can do picture in picture
By edong in forum Video ConversionReplies: 25Last Post: 17th Dec 2013, 15:50 -
How do you overlay video for a picture in picture?
By orionredwing in forum EditingReplies: 6Last Post: 15th Dec 2013, 22:58
