Assuming you didn't specify that DVDXCopy keep the copy protection (highly unlikely), you should be able to just copy the VIDEO_TS* folder directly to your hard drive. You could even use 7-Zip or Bandizip to extract the folders to your hard drive.
*99.99% of the time, the AUDIO_TS folder is not used by Video DVDs and is empty.
BTW, you don't rip to .mp4. A rip is and exact bit for bit copy of the contents of your Video DVD, either to .iso or VIDEO_TS and AUDIO_TS files, never anything else. If you're converting to .mp4 or any other container, directly with a program or as a separate process, you're encoding the Video DVD rip. Keeping this is mind makes understanding what you want to do easier if you have questions later.Last edited by lingyi; 8th Dec 2018 at 02:03.
Thank you lingyi! Copying the VIDEO_TS folder to a hard drive, then using HB to access the folder worked perfectly. Much appreciated.
ImgBurn L-EC Uncorrectable Error Ripping Commercial Discs
By koberulz in forum DVD RippingReplies: 31Last Post: 29th Aug 2019, 14:38 -
ripping old VCD / DVD discs ??
By kenny1999 in forum Newbie / General discussionsReplies: 9Last Post: 20th Sep 2018, 14:43 -
Ripping and Converting VideoNow Discs
By coondog1234 in forum Video ConversionReplies: 2Last Post: 3rd Dec 2015, 13:14 -
Ripping discs and resetting region code
By whoisquilty in forum MacReplies: 2Last Post: 27th May 2014, 13:23 -
Ripping discs to MKV, full framerate.
By xtremeD63 in forum Blu-ray RippingReplies: 23Last Post: 15th Jan 2014, 14:29
