Maybe this is just a typical situation with VCD, but I notice a subtle 'flicker' or 'pulsing' in the background particularly if the background is dark.
Is this something that others have noticed, or is there something in the conversion process that can eliminate this?
I convert using TMPGEnc. Other than that everything else is great.
Thanks.
I know exactly what you're talking about, happens to me also when background is stationary with compliant VCD.
If your DVD player can handle XVCD, increase your bit rate to 2000 to 2300 kbps and that will eliminate the slight pulsating.
HD - DVD = Movie flicker or something
By Electric Blue in forum Video ConversionReplies: 25Last Post: 18th Jun 2011, 12:43 -
Flicker on DVD Menu
By Funky Monk in forum Authoring (DVD)Replies: 1Last Post: 12th Sep 2009, 17:42 -
Strange flicker on my DVD-Rs
By ministry88 in forum DVD & Blu-ray RecordersReplies: 17Last Post: 6th Mar 2009, 22:43 -
Problem with Pink Floyd Pulse DVD
By altsouza in forum Authoring (DVD)Replies: 9Last Post: 4th Sep 2008, 18:48 -
Flicker effect
By wan2no in forum EditingReplies: 1Last Post: 26th Jul 2007, 20:38
