I recovered this system, including the sub-woofer and 5 mini speakers. I desperately need the user manual.
The model number is STS32 M
It was manufactured in October, 2001
Thank you
No. Not broken. But, there are a couple minor issues.
Mostly, the manual describes how to set-up the various found configurations. -
Sometimes similar models have similar settings:
https://www.manualslib.com/manual/185925/Venturer-Sts91.html -
Hey John -
Thanks for that idea. I did go check that different model user manual, but no luck there. The newer system uses an upgraded Dolby STS system that automatically selects the best speaker configuration option based on what component is in use, and indeed, what format the display is using. My issue is how to set the home theater system up to use all 6 speakers with an analog stereo input from the smart TV that I mostly use to play music videos through YouTube or Pandora. So far, I've only been able to get two channels (left and right front) and the sub woofer to play together.
View movies from a NAS box on a Vizio M65-E0 Home Theater Display
By ellermld in forum Newbie / General discussionsReplies: 1Last Post: 17th Oct 2017, 23:14 -
Playing sound back though Old Hi-Fi System from DVD
By CP/M User in forum Off topicReplies: 6Last Post: 5th Sep 2015, 10:47 -
Subtitles on Seagate Free Agent Theater +
By drbenco in forum Media Center PC / MediaCentersReplies: 8Last Post: 25th Feb 2015, 15:28 -
Home Theater -- No forum for them on VideoHelp I guess.
By marjamar in forum Newbie / General discussionsReplies: 6Last Post: 31st Jan 2015, 17:17 -
Region free code for LG BH7220B home theater
By helpneeded88 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 6th Mar 2014, 12:06
