Hi, on my PC I usually play my media through MPC HC with hdmi audio to my TV . But suddenly there wasnt any audio playing and I noted that in the Audio Rendering options where you can change the audio device output there was a duplicate of every audio device, that is 2 speakers, 2 digital output, and 2 hdmi, the thing is that only one works and the wrong one was selected.
Its been a week form that time and every time I start playing something I have to check and select the working audio output.
So any help will be appreciated before I start to uninstalling things.
The usual solution is to use the System Restore function in Windows. It will get your PC back to the state it was in prior to these unwanted changes.
Every 6th frame is duplicated
By jorge69696 in forum Video ConversionReplies: 13Last Post: 29th Oct 2018, 13:27 -
Avidemux audio devices: win32 or dummy :(
By phickspc in forum Newbie / General discussionsReplies: 4Last Post: 29th Feb 2016, 16:48 -
Strange Audio issue on Mobile Devices - Video taken with Sony HD Cam
By timothy001 in forum AudioReplies: 12Last Post: 6th Aug 2015, 11:38 -
No Audio Capture on any Record stream devices/apps ? Help !
By Atotaloss in forum Video Streaming DownloadingReplies: 2Last Post: 29th Oct 2014, 16:44 -
removing duplicated frames from YT video
By adom in forum EditingReplies: 7Last Post: 23rd Aug 2014, 12:19
