If I connect a NTSC Hi8 camcorder to a PAL DVD recorder and play a NTSC Hi8 tape on the camcorder, can the DVD recorder record the signal?
Results 1 to 9 of 9
Some of the OLDer Philips machines could record both NTSC and PAL, but those are long dead by now.
This one did:
https://www.amazon.com/Philips-DVDR985-Progressive-Scan-Recorder-Player/dp/B00005YXZE
I have my old one in my basement. Took HOURS to finalize the disc, so it was finally retired.
It obviously could not record PAL via the tuner, but could record a straight PAL signal through
any of the other inputs. -
What I think my friend is saying is that if you have a NTSC input then the recorder would record in NTSC.
I can not see any recorder doing a standards conversion.
The other thing with 'ancient' machines would be their tolerance with today's faster media. My first recorder would only accept 2x disks. It baulked at 4x (2x compatable) ones. -
Here are a couple that record PAL or NTSC. You need to search for "multi system DVD recorder."
https://www.worldwidevoltage.com/panasonic-dmr-eh68-multi-system-dvd-recorder.html
https://www.amazon.com/Pioneer-DVR-550H-S-Multi-System-Recorder-Built/dp/B000QUN5HE
Hi8 capture using Digital8 camcorder - Edge color issues
By memrah in forum Capturing and VCRReplies: 56Last Post: 4th Jan 2023, 09:36 -
best quality playback and capture for preserving PAL Hi8 camcorder footage?
By HuBanfiT in forum Capturing and VCRReplies: 13Last Post: 29th Jul 2018, 21:24 -
High-end HI8 deck / camcorder to capture PAL video8 tapes
By FLP437 in forum Capturing and VCRReplies: 2Last Post: 29th Mar 2016, 10:28 -
No way to get digital channel signals to old DVD-Recorder
By Fred999 in forum DVD & Blu-ray RecordersReplies: 11Last Post: 20th Sep 2015, 10:52 -
Can Hi8 distorted tapes recorded on 8mm camcorder, play on Hi8 camcorder?
By RebeccaJB in forum Newbie / General discussionsReplies: 7Last Post: 27th Jul 2014, 17:39
