I would like to add subtitle to 4K UHD
But i can't find any program that can remux 4K UHD for add my subtitle
So can i mux or remux 4K UHD ?
Yes, you can. There are numerous tools that could do this for you; I recommend MKVToolnix or ffmpeg.
The free solution would be to mux it with tsMuxeR. Then use jdobbs' free tool TSM2UHD to fix the output so it is UHD disc compatible.
If you don't want to do it manually the newest version of BD-RB supports UHD backup allowing you to strip subtitles.
Some standalone UHD players have issues with tsMuxeR, but the good news is jdobbs is currently developing his own muxer to create UHD discs. -
I prefer physical disc than mkv fileOriginally Posted by KarMa
price is so expensiveOriginally Posted by flashandpan007
i would like to add subtitle and keep both menu and special featuresOriginally Posted by Vidd
tsmuxer,TSM2UHD and BD-RB can't do that
ismdownloader failed to mux files - how to mux them?
By renesti in forum Video Streaming DownloadingReplies: 2Last Post: 31st Mar 2018, 10:36 -
Issue with 4k/UHD Remux - playback looks poor quality + 0% GPU usage
By Deep Euphoria in forum Software PlayingReplies: 9Last Post: 25th Jan 2018, 17:02 -
UHD BD Specs
By SameSelf in forum Newbie / General discussionsReplies: 18Last Post: 4th Jan 2017, 16:59 -
Sony on UHD
By SameSelf in forum Latest Video NewsReplies: 1Last Post: 1st May 2016, 01:48 -
UHD TV shopping
By RKF in forum DVB / IPTVReplies: 24Last Post: 10th Aug 2014, 21:09
