So I have a Sony MiniDV camcorder that slacks and wrinkles the tape whenever it is rewinding. I tried cleaning the pinch roller, nothing changed. I tried replacing the pinch roller, nothing changed. I've rewound a tape while the unit was open and it seems that the tape is moving abnormally around the pinch roller and "exit" slot of the cassette (the "entrance" side during playback). By abnormally I mean up and down. This does not occur during fast-forwarding or normal playback. It's happened a few times in the past but now seems to be happening regardless of what brand of tape is used.
What else can cause this? I did have to adjust the tensioner a bit but I would think that would cause issues during playback as well. Help?
Thanks!
Results 1 to 11 of 11
Does the feed reel move at a constant speed in rewind?
It seems to - I can take a closer look later. Actually, sometimes the playback supply reel (acting like the take up reel during rewinding) locks up when a damaged section of tape is run through.
Actually, a few more things to note: It only seems to do it if the deck is oriented the way it would be in a VCR, although when it's oriented as if the camera is upright, I do hear some slight speed changes during rewinding. Actually, sometimes, when I play a tape backwards slowly (-×1 or slow), I get a C:31:23 (supply reel fault) error. Is it possible that the supply reel table is cracked (and not running correctly)? Could that cause issues similar to low tension?Last edited by MiniDVLover; 30th Nov 2018 at 06:45.
Sounds like not enough torque to the supply reel in rewind. Could be bad contact with the idler or a bad clutch. Or a weak power train to the capstan motor.
Okay, I've taken a closer look, and it's slacking even in normal playback, just not as severely. I played with the TG6 alignment - no avail. The creasing is occurring between the capstan/pinch roller and TG6/TG5.
Could THIS be tension-related? Why doesn't it happen during fast-forwarding?Last edited by MiniDVLover; 30th Nov 2018 at 11:44.
Could be worn out or misadjusted brake on the supply reel.
It's a complicated mechanism and everything wears at once — so tends to break down at the same time. It wouldn't surprise me if brakes were goofed on both reels and there is a problem with idler contact as well. All common stuff.
Best free software to capture from a MiniDV camcorder WITH Firewire?
By kelemvor in forum Capturing and VCRReplies: 1Last Post: 6th May 2018, 21:48 -
miniDV camcorder file transfer issue
By theodurry in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 8th May 2017, 03:40 -
MiniDV camcorder as a capture device
By Mr Chris in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 14th Jul 2016, 10:51 -
Recommend a minidv tape camcorder with hdmi, only for *playback*
By Movie-Maker in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 9th May 2015, 17:54 -
Help with MiniDV camcorder (malfunctioning) and converting tapes
By rick6668 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 4th Apr 2014, 19:34
