What are my options for combining multiple mp3 files into one large file without quality loss? A relative recently passed on some 1970s top 40 airchecks to me he recorded and converted to mp3 and for some reason each hour aircheck is in 20-25 parts. I would like to combine each hour recording into a single mp3 file without suffering a loss in quality.
Perhaps this, but it will only work if the sample and bitrates are similar
https://www.videohelp.com/software/mp3DirectCut -
Mp3DirectCut will definitely do it. You can open multiple instances, and copy all or part of an MP3 using one instance and paste it into another. If the second instance has already opened an MP3, the pasted MP3 can be appended to it.
I do have mp3DirectCut. I have used it for splitting mp3s. It sounds like you just paste it into an open file?
Just putting the files into a ZIP archive could do the trick, depending on what you intend to do with them. At least VLC Media Player can play media files from common archive types, and skip between individual tracks, perhaps other players can as well. Preferably use the “store” option (no compression).
In the past, when I was heavily using the eMule P2P network, so more than 10 years ago, I've seen occasionnally files shared as MP3, which were in fact ZIP archives with their extensions changed as MP3, and they would play fine as MP3 with whatever I was using at the time, so it was already possible then.
(And it most likely works even if audio parameters are vastly different.)
Batch combining multiple audio files with same picture to create mp4 files
By MD_89 in forum AudioReplies: 25Last Post: 1st Dec 2018, 23:29 -
Combining multiple Video files and compressing
By unknown in forum Newbie / General discussionsReplies: 10Last Post: 8th Nov 2018, 03:46 -
Split large AVI from DV tape into multiple files by timecode
By gsull111 in forum Newbie / General discussionsReplies: 15Last Post: 8th May 2018, 07:30 -
Combining multiple video 8 captures to create one higher quality capture?
By Drunkin Dynasty Dave in forum Capturing and VCRReplies: 1Last Post: 25th Dec 2017, 23:04 -
Combining multiple MTS files into one with transitions
By Cyber Akuma in forum Newbie / General discussionsReplies: 12Last Post: 9th Jul 2015, 07:55
