Hi, I wanted to know if it is possible to have PotPlayer briefly show the progress bar whenever I time jump while a video is in full screen? I am pretty sure that this is how e.g. VLC does it and it gives a good overview to the user on the absolute location in the currently played back video.
I realize that there is an info text in the upper left corner whenever I time jump but this is more abstract than really seeing the progress on a bar.
Thanks for any help!
When in Full Screen mode, if you move your mouse to the bottom of the screen - then the progress panel appears.
Thanks for your answer!
I know that but wanted to know if there is a way to see the progress bar each time I make a jump (to have better orientation where I am in the video file). -
I already requested it in the official forum, probably also via email, or someone re-send that suggestion, but author did not added it. You can try it too, via email, homepage, scroll down, CONTACT US.
You can try to create a macro with AutoHotkey or HotkeyP.
Oh, this topic is from 2018 and reply from 2020, doesn't matter.
Can FFMPEG show a percentage done or a Progress Bar?
By marcorocchini in forum Newbie / General discussionsReplies: 13Last Post: 19th Jul 2020, 23:14 -
How can I show Windows Taskbar when Potplayer is in Restore Screen mode?
By SalFrank in forum Software PlayingReplies: 2Last Post: 16th Apr 2018, 14:48 -
POTPLAYER - Show seek bar when seeking
By skribby in forum Software PlayingReplies: 2Last Post: 9th Jun 2016, 15:33 -
PotPlayer - Zoom video region to full screen
By masster in forum Software PlayingReplies: 5Last Post: 22nd Nov 2015, 13:46 -
PotPlayer: Can't Cycle AR in Full Screen
By Michael Linder in forum Software PlayingReplies: 1Last Post: 29th Jun 2015, 02:45
