Results 1 to 13 of 13
  1. Here's my code.
    MPEG2Source("VTS_01_1.d2v")
    D = QTGMC(Preset="Medium", FPSDivisor=2)
    TFM(D2V="VTS_01_1.d2v", slow=2, pp=4, clip2=D)
    TDecimate(mode=1)
    Crop(0, 0, -4, -0)
    KNLMeansCL(D = 1, A = 1, h = 4, device_type="auto")
    DeHalo_alpha_mt(rx=2.0, ry=2.0, darkstr=1.0, brightstr=1.0, lowsens=50, highsens=50, ss=1.5)
    There's a few seconds where a mouth has a few combed frames in my output. I can't seem to remove it. Any help using TFM/TDecimate?
  2. You can try reducing cthresh or MI in TFM.
  3. Originally Posted by jagabo View Post
    What's MI?
  4. You know, you could just try reading the TFM doc to get your questions answered:
    MI -
    The # of combed pixels inside any of the blocky by blockx size blocks on the frame
    for the frame to be detected as combed. While cthresh controls how "visible" the
    combing must be, this setting controls "how much" combing there must be in any localized
    area (a window defined by the blockx and blocky settings) on the frame. Min setting = 0,
    max setting = blocky x blockx (at which point no frames will ever be detected as combed).
    Default: 80 (int)
  5. Originally Posted by manono View Post
    MI -
    Default: 80 (int)
    I'm gonna try setting the cthresh to 4
  6. Originally Posted by Vitality View Post
    You do that. And don't forget to put on "Display=True" in TFM (just for testing) so you can see how many frames are needlessly deinterlaced.
    Me, I find that adding Vinverse() after the IVTC is often the better solution to the problem of leftover interlacing.
  7. Originally Posted by manono View Post
    So Vinverse() after TFM/TDecimate?
  8. It seems totally wrong to me to deinterlace (QTGMC) first and then do IVTC. If your material is telecined, then QTGMC is completely unnecessary, unless you later want to use it just for denoising (and there are better options for that).
  9. Originally Posted by johnmeyer View Post
    no tfm calls qtgmc
  10. In that script the QTGMC frames are only used when TFM's post processor decides a frame is still interlaced after field matching (because of orphaned fields or some other problem). Instead of using its own deinterlacer TFM uses the frame from QTGMC.
    Oops! Thanks for that. I didn't see the "Clip2=D" statement on the TFM line.
  12. Originally Posted by Vitality View Post
    Yes.
  13. Originally Posted by Sharc View Post
    Yes.
    D = QTGMC(Preset="Slower", FPSDivisor=2)
    TFM(D2V="VTS_01_1.d2v", slow=2, cthresh=4, mi=0, pp=7, clip2=D)
    TDecimate(mode=1)
    vinverse(sstr=2.7, amnt=255, uv=3, scl=0.25)
    Crop(0, 0, -4, -0)
    This appears to have fixed everything
