[QUOTE=RS456;2535124] My choice is Hauppauge USB-Live2. Use it with VirtualDub, VirtualVCR or similar for lossless (huffyuv, UTVideo) capturing and compress later offline in a second step
http://www.hauppauge.com/pages/products/data_usblive2.html
Results 31 to 41 of 41
Its been a few months but I got a pci card at a reasonable price. I did a vhs conversion as a trial. Please tell me what you think. I posted a screen shot.
[Attachment 47780 - Click to enlarge] -
Crushed blacks, poor horizontal time base, bad upscaling, wrong aspect ratio, bad deinterlacing...
Can you explain each one ? I am surprised you saw that many issues. Only issues I saw were the distorted bar on the bottom and blurry image which is to be expected in vhs. Regarding upscale I didn't do anything. My combo player does it automatically.
I am new to this so please circle all the issues in the screen shot and repost it..Last edited by RS456; 9th Jan 2019 at 14:52. Reason: elaborating
For a still I can see two problems, The aspect ratio is dead wrong, VHS is 4/3 not 16/9, and luma level is too low.
Ok for the ratio I have to see my manual if I can disable the auto upscale. Is the ratio error the reason for the distortion at the very bottom of the screen (small bar strip). I am not sure if I can adjust the luma level in the VCR. I might have to do that in reencoding in the computer. Anything else other than those problems.
jagabo mentioned the deinterlacing. Don't deinterlace. There must be a way to turn it off. He also mentioned the lack of timebase correction in your VCR
Maybe not. What about in your capture program? If not, look for a different one. Or you used a DVD recorder for the capture? Bad idea. If you don't have any choice in the matter, look in the manual or in the menu for a way to adjust the brightness and contrast. And I really doubt you're forced to make it 16:9 and upscale. You want to cap at 720x480. Then you can fix things later on.I am not sure if I can adjust the luma level in the VCR. -
The weird strip on the bottom is not meant to be seen by conventional TV's since they have the overscan feature built into them, Your DVD mpeg encoder is just scanning the whole frame including the control data, You can crop it in software later if you want to.
So that is not a distortion error and I can crop without losing any of the original video?
I looked an the manual. I can adjust the ratio. The 16:9 and upscale is set by default and can be adjusted according to manual. For the capture I used Hauppauge Collassus and capture is done in my computer. The Software I used is the software that came with the card.Originally Posted by manono -
New samples. All these are in 480. The screenshot is somehow showing more than that.
[Attachment 47791 - Click to enlarge]
[Attachment 47792 - Click to enlarge]
[Attachment 47793 - Click to enlarge]
[Attachment 47794 - Click to enlarge]
Please tell me if they are better than my previous sample. If so which one.Last edited by RS456; 11th Jan 2019 at 17:18. Reason: Elaborating
VHS waviness in digital conversion - comparison screenshots
By Brad in forum Capturing and VCRReplies: 16Last Post: 19th Feb 2025, 06:56 -
VHS to Digital Help Please
By coffeeboy in forum Newbie / General discussionsReplies: 4Last Post: 12th Apr 2017, 14:57 -
Trouble accessing video files after vhs to digital conversion
By wallabyact in forum Video ConversionReplies: 3Last Post: 12th Nov 2015, 11:35 -
PAL VHS tapes to digital conversion help
By alfaromeo155 in forum Video ConversionReplies: 22Last Post: 31st Jan 2015, 20:35 -
VHS to digital - help
By freee in forum Video ConversionReplies: 77Last Post: 28th Nov 2014, 07:43
