I just recently started using Windows 10. Just like with Windows 7, i installed VLC and K-LITE codecs pack, both x86. I used to pick dxva copy-back for acceleration and madvr as video renderer, lav filter for video and audio - the usual stuff that always worked in Windows 7. I never had problems opening any file in VLC or MPC.
I have lots of DVD stuff in my hard drive, the usual stuff, packed in VIDEO_TS folders. I was horshacked when i tried to drag them on top of VLC or MPC and found that half of them would not open - what?
Surely someone knows what's going on????
Ok, guess what, i found out that much of my DVD content has been reduced in size. All of the files were located on a hard drive, separate from the operative system SSD. I did nothing with that HDD, once installed Windows per new and got all drivers working, i found this BIZZARE deficit in size.. Some of my ordinary avi and mkv files also have been reduced. WEIRD. HDD SMART shows everything in order..
Something weird about your setup. Been using VLC + LAVfilters on Win10 (x64) with both (decrypted) DVDs, mounted ISOs, and VIDEO_TS files&folders for 2 years now with no problems.
And if it's just a rip, there should and would be NO change in filesize, regardless of original optical disc source vs SSD, or HDD.
Scott -
Try right clicking on a file and looking at it's properties. If "size on disc" is smaller than "size", it's probably because NTFS file compression has been enabled.
http://www.ilovefreesoftware.com/06/windows-10/use-file-folder-compression-windows-10.html
It shouldn't effect the ability to drag and drop, as far as I know.
MPC-HC and vlc color difference
By hbloc in forum Software PlayingReplies: 7Last Post: 24th Jul 2018, 17:42 -
DVD only playing in MPC, not working in VLC or anything else
By twinaleblood in forum Video ConversionReplies: 1Last Post: 4th Jul 2016, 03:59 -
VLC vs MPC-HC Colors?
By thatslikeaboss in forum Software PlayingReplies: 2Last Post: 1st Mar 2016, 10:14 -
Screen freeze one second when i open a video with MPC or VLC
By skim in forum Newbie / General discussionsReplies: 3Last Post: 18th Jan 2015, 12:29 -
VLC Potplayer MPC-HC . . .
By vhwul62 in forum Software PlayingReplies: 7Last Post: 6th Jan 2015, 01:12
