Hi, but sorry I'm a ***
please my answer is: I need to reduce a little the global chroma level of a video file. How is possible it using avisynth?
thanks
Can you clarify what you mean by "global chroma level"?
Did you mean reduce saturation ? If so, you can use tweak
http://avisynth.nl/index.php/Tweak
eg.
Tweak(sat=0.8, coring=false) -
[Attachment 47299 - Click to enlarge]
yess thansk
Avisynth fix Chroma artifacts in PAL DVD CGI cartoon
By Wizard81 in forum RestorationReplies: 1Last Post: 11th Oct 2018, 10:47 -
how can i offset the frames on the chroma channel in avisynth
By flashlight in forum RestorationReplies: 11Last Post: 5th Mar 2018, 19:15 -
Avisynth filter from Chroma noise removal?
By Srivas in forum RestorationReplies: 5Last Post: 27th Dec 2015, 08:49 -
Avisynth, Change Chroma not Luma
By lolman in forum EditingReplies: 4Last Post: 18th Oct 2015, 11:33 -
MKV to MP4 Reduce level.
By PedgeJameson in forum Video ConversionReplies: 1Last Post: 5th Apr 2015, 03:26
