access violation at address0041EAC7 in module "smartripper.exe". Read of address 019A4008. it is a double sided dvd?
not sure what the error is but i think T2 has multiple angles, dont know if that has anything to do with the problem or not but try dvd decrypter instead of smartripper. i think dvd decrypter might work better with discs that contain multiple angles, i never have figured out how to choose only angle 1 with smartripper.
Bondiablo, in "movie mode" smartripper automatically chooses the first angle for u (99% of the time, smartripper does a good job in selecting the right angle, etc. for you to rip)
as for T2: ultimate ed., i was using older version of smartripper, and it couldn't even unlock the drive correctly (most likely cuz of all the multi-angles in it, and there's A LOT)
best bet is to use dvddecryptor w/ MULTI-ANGLE PROCESSING ENABLED IN THE OPTIONS MENU (worked like a charm)
Error while Ripping DVD
By harishkumar09 in forum DVD RippingReplies: 11Last Post: 25th Jan 2011, 02:50 -
Error when launching VOB2MPG 3 PRO in Vista Ultimate 64bit
By ghostwulf in forum SVCD2DVD & VOB2MPGReplies: 13Last Post: 20th Mar 2009, 06:28 -
Error ripping BATTLE ROYALE 2: REVENGE. Help?
By shuya_nanahara in forum DVD RippingReplies: 2Last Post: 22nd Mar 2008, 07:37 -
Help Ripping DVD(Error)
By LCE in forum DVD RippingReplies: 2Last Post: 2nd Jan 2008, 12:45 -
Walk The Line Ripping Error?
By LCE in forum DVD RippingReplies: 4Last Post: 12th Nov 2007, 14:36
