Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
  1. I'm sorry if this sounds like a dumb question, but does the bluray drive you use actually affect the picture quality? I recently replaced my drive I use as I was having problems with the old one - it skipping a lot - but now that i'm using the new drive - a Pioneer BDR -XDO5TS - I'm sure the picture quality has decreased . The picture seems softer and less sharp.
    Mar 2008
    I don't think it's possible - unless you're using different software
