Trying to transfer a VHS to DVD, which has cine film on it (standard 8- no audio) but it has a dubbed music track in the background.
The background music track will play for a few seconds and then it drops out.
I have also taken out the tape, wound it forward and tried in a different VCR, at a different position. The same thing occurs?! A few seconds of audio, but then nothing.
Visually, it's great quality.
Any ideas please folks?
Do you suspect an issue with the vcr or a problem with the capture?
What have you done to narrow it down? Did you attempt to play the vcr thru the TV to see
if the problem still occurs?
What is the capture device and what software are you using ? -
Thanks Dave.
No capture device, no software. This is just playing through normal VCRs? Neither VCRs I’ve used are faulty, nor are the TVs. -
Have you tried switching the audio track? I would first try playing only the Hi-Fi track, and then repeat, but this time set the VCR to only play the linear track (often called "Normal" in the menu).
See if it drops out at the same point each time, with both tracks.
Since it is only dubbed music, you should easily be able to replace it, possibly with something even better. -
You are a superstar! Can’t believe it was something so simple as switching the audio track!
The choices I had were left, right ( neither of which gave me any audio), mixed or the one I chose, mono, which I thought was ideal.
which filters to remove dropout or comets, and where get them
By spiritgumm in forum RestorationReplies: 13Last Post: 24th Feb 2021, 21:02 -
vhs two audio languages
By jamespoo in forum MediaReplies: 9Last Post: 15th Sep 2017, 10:12 -
What tape format will create this dropout?
By AVCHDfreak in forum Newbie / General discussionsReplies: 5Last Post: 29th May 2015, 22:18 -
VHS audio clicks
By Hypersonic1 in forum RestorationReplies: 7Last Post: 11th Mar 2015, 08:19 -
DVDs that were made from broadcast tapes - dropout correction?
By 90sTV in forum Newbie / General discussionsReplies: 1Last Post: 10th Oct 2014, 07:39
