Page 3 of 3
FirstFirst 1 2 3
Results 61 to 66 of 66
  1. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    In addition to what Sharc said, some comment on my side:
    Love Danguard! Animation capture is not the best to judge for quality.
    I did not notice the black crush:
    There are "black frames" on both catures.
    The 2 captures are very similar, once tweaked for similar look:
    with image slider: https://imgsli.com/MzQ4NDk0
    The canopus capture has a distortion to the left on the top of the frame at the end of the video.
    The canopus capture has some more "artifacts" on the red color parts, and in general more noise in the borders between areas of different colors:
    with image slider: https://imgsli.com/MzQ4NDk1
    We did some comparison betweek BlackMagic and Canopus some time ago: https://forum.videohelp.com/threads/410062-Which-capture-of-my-old-VHS-looks-the-best
  2. Originally Posted by lollo View Post
    OMG hauppage LIVE 2 USB thing looks better than the BM 4K and ADVC100 ??
    I saw on forum that Lordmsurf is an expert of BAD hauppage USB stick... i have an WinTV-HVR-900 but i was thinking anythink was better than that...
    is the WinTV-HVR-900 a poor device? what was the best hauppage USB ?
  3. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    Hauppauge USB-Live 2 is a complete different device than the HVR Series. Yes, is a nice capture card and so recommended, provided you feed it with a Y/C signal time base corrected.
    But as you have seen, the Canopus ADVC (DV approach) is a valid alternative (with lower quality, easier usage and solid results).
  4. Originally Posted by lollo View Post
    Hauppauge USB-Live 2 is a com...... with a Y/C signal time base corrected.
    i found 36 of these USB live 2 , as an old new stock.
    i will buy one to see how works on PAL
  5. Originally Posted by lordsmurf View Post
    "Why does grandma have a sunburn in our Christmas videos?"
    if you know... this was solved on ADVC110 ?
    Never was -- and can never be.
    It's byproduct of 4:1:1 NTSC and the DV codecs used. (PAL 4:2:0 is less bad on color accuracy.)
