Been using it for DVDs but need something for BR video files and everything I've found to do it cost money. Not worry about decryption so if it doesn't do that on its own thats fine.
Suggestions?
remux to mkv using mkvtoolnix/makemkv try MKV Cutter, might not work, might be buggy, but is probably worth a try.
users currently on my ignore list: deadrats, Stears555, marcorocchini -
If you got an unencrypted disc on why not use mkvtoolnix, open the playlist you want and remux it to mkv?
Selur I had to figure out how to put the time codes in manually but mkvtoolnix did the trick! Thanks!
Ah okay, you used mkvtoolnix to also cut the source directly, I thought only to use it to create the mkv and then use MKC Cutter for the cutting.
MKV Cutter tries to be frame accurate, mkvtoolnix only cuts on key frames, if that is enough, mkvtoolnix is the way to go.
-> happy that worked out for you
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini
M2ts files and Bluray Menu?
By malimuc in forum Authoring (Blu-ray)Replies: 6Last Post: 8th Jun 2017, 08:27 -
Can mp4 files be burned directly to a BluRay disc w/o converting?
By videobruce in forum Authoring (Blu-ray)Replies: 7Last Post: 30th Oct 2016, 15:57 -
BluRay player won't play certain MKV/MP4 files
By Dan091 in forum Newbie / General discussionsReplies: 13Last Post: 22nd Mar 2016, 01:28 -
Bluray authoring: Could I put some image files into AUXDATA folder?
By hxuanyu in forum Authoring (Blu-ray)Replies: 12Last Post: 6th Feb 2015, 19:37 -
Yet another NOOB post =). Bluray to streamable files
By donotron in forum Blu-ray RippingReplies: 4Last Post: 15th Apr 2014, 08:25
