Hello, everybody! I have a question, how you set your PC to speed up Movie Studio Platinum 13? I know is old software ... Just want to know the settings that you use and try myself. Last time I just stitched some videoclips it took 8 hours to render 14 minutes.
If you are running a 32bit version of XP, you need 4GB RAM. For 64bit, 8GB is enough with an older PC.
If it takes 8 HRs to encode a 14 min clip, then you have a problem. If I assume a DVD compliant file, that's slow.
But what's your source video type and your output video type?
Encoding speed is mostly related to CPU speed, RAM availability, Hard Drive speed and encoding settings.
If you have maybe 1GB RAM, that could be a bottle neck. If you are encoding to MPG2 for DVD, the encoding settings are mostly set by the codec.
Other codecs are more flexible for settings. Filtering also slows down an encode.
And I moved your post to a new thread where you may get more responses.
Moderator redwudz -
I use Vegas Pro, but the setting options should be the same. Go into your setting in Movie Studio and look for your RAM option. It will say how much RAM your computer has on the right and you can up the number the program uses, which should make it run faster/better. The more RAM you assign to it the better it should work, but if you use majority of it on Movie Studio, you’re other programs won’t have as much RAM to work with. Hope that helps.
Audio out of sync after rendering with Movie Studio Platinum 12.0
By RecklessVillen in forum Newbie / General discussionsReplies: 4Last Post: 28th Jan 2015, 04:57 -
Broken pixels? Vegas Movie Studio Platinum 10
By Krisperr in forum EditingReplies: 3Last Post: 17th Sep 2014, 17:20 -
strange pixelization in videos using Sony's Movie Studio Platinum 13.
By needoriginalname in forum EditingReplies: 5Last Post: 1st Sep 2014, 21:37 -
Combining movie segments (Sony Movie Studio Platinum 13)
By Cellmate in forum EditingReplies: 5Last Post: 13th Aug 2014, 14:27 -
Sony Movie Studio Platinum 12 Suite can it do this ?
By s8n in forum EditingReplies: 4Last Post: 20th Dec 2013, 11:02
