Results 1 to 21 of 21
  1. Hi all,
    I've encoded a video that plays well with my media player (cool ) but when i encode another one, it doesn't play at all.
    Video that plays well :
    Format : Matroska
    Format version : Version 4
    File size : 280 MiB
    Duration : 2 min 16 s
    Overall bit rate : 17.2 Mb/s
    Encoded date : UTC 2018-03-19 14:00:10
    Writing application : mkvmerge v21.0.0 ('Tardigrades Will Inherit The Earth') 64-bit
    Writing library : libebml v1.3.5 + libmatroska v1.4.8
    Video
    Format : AVC
    Format profile : High@L4.1
    Format settings : CABAC / 3 Ref Frames
    Format settings, CABAC : Yes
    Format settings, RefFrames : 3 frames
    Codec ID : V_MPEG4/ISO/AVC
    Bit rate : 12.0 Mb/s
    Width : 1 920 pixels
    Height : 804 pixels
    Display aspect ratio : 2.40:1
    Frame rate mode : Constant
    Frame rate : 23.976 FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.324
    Stream size : 196 MiB (70%)
    Writing library : x264 core 148 r2708 86b7198
    Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=16 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=12000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
    Language : English
    Default : Yes
    Forced : No
    Color range : Limited
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio
    Format : DTS XLL
    Format/Info : Digital Theater Systems
    Commercial name : DTS-HD Master Audio
    Codec ID : A_DTS
    Bit rate mode : Variable
    Bit rate : 5 163 kb/s
    Channel(s) : 8 channels
    Channel layout : C L R LFE Lb Rb Lss Rss
    Sampling rate : 48.0 kHz
    Frame rate : 93.750 FPS (512 SPF)
    Bit depth : 24 bits
    Compression mode : Lossless
    Stream size : 84.0 MiB (30%)
    Language : English
    Default : Yes
    Forced : No
    Video that doesn't play (shortest one for faster encoding test) :
    Format : Matroska
    File size : 83.9 MiB
    Duration : 56 s 864 ms
    Overall bit rate : 12.4 Mb/s
    Encoded date : UTC 2018-11-04 14:52:55
    Writing application : mkvmerge v28.2.0 ('The Awakening') 64-bit
    Writing library : libebml v1.3.6 + libmatroska v1.4.9
    Video
    Format : AVC
    Duration : 56 s 849 ms
    Width : 1 916 pixels
    Height : 804 pixels
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.325
    Stream size : 81.7 MiB (97%)
    Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=18 / lookahead_threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=16 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=12000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
    Language : English
    Default : Yes
    Forced : No
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Commercial name : Dolby Digital
    Codec ID : A_AC3
    Bit rate mode : Constant
    Bit rate : 320 kb/s
    Channel(s) : 2 channels
    Channel layout : L R
    Frame rate : 31.250 FPS (1536 SPF)
    Bit depth : 16 bits
    Compression mode : Lossy
    Stream size : 2.17 MiB (3%)
    Language : English
    Service kind : Complete Main
    Default : Yes
    Forced : No
    Text
    Format : PGS
    Muxing mode : zlib
    Codec ID : S_HDMV/PGS
    Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
    Duration : 8 s 8 ms
    Bit rate : 29.3 kb/s
    Count of elements : 6
    Stream size : 28.6 KiB (0%)
    Language : French
    Default : Yes
    Forced : No
    Audio codec and subtitles should not be the source of the problem since AC-3 and PGS are well played in other videos.
    Any ideas, i'm stucked...
  2. Whenever HW decoder is involved setting 'bluray_compat=1' should be used for encoding.
  3. Originally Posted by umbie View Post
    Try to remove them anyways, just for testing. Only other differences I see: 1920 vs 1916 pixel width (should not be a problem), different MKVToolNix version (not aware of any problems with 28.2.0, though).
    What player are you using?
  4. Thank you for your fast answers
    What i've tried (with no audio nor subs in all tests) : 1/ 1920 instead of 1916, 2/ add 'bluray_compat=1' with 1916 width, 3/ add 'bluray_compat=1' with 1920 width.
    None works
    I'm using Netgear NeoTV 550 (old but works well)
    Same encoder parameters, different playing... so strange (i've tested with the source file and it is playing well, but i wish to have a lighter file without losing too much quality)
  5. If you remux the first, working file with 28.2.0, does it still work?
  6. it was remux with this version already
  7. What do you mean? In your first post it says "Writing application : mkvmerge v21.0.0 ('Tardigrades Will Inherit The Earth') 64-bit"?
  8. The first file was encoded from another source file. I've just try to remux the first file with 28.2.0, it plays well.
    What I mean, is that the source file for the second file was remux from a mpls file with 28.2.0. This source plays well, but not the reencoded one.
    I use HandBrake 1.1.2 for encoding. I've tried to play the file directly after encoding... not working in my player, then try to remux it with 28.2.0 with no success
  9. Test the attached samples.
  10. A & D are playing while not B & C
  11. Some players don't like sub compression (zlib)
    Text
    Format : PGS
    Muxing mode : zlib
  12. Originally Posted by umbie View Post
    Ok, that is weird.
  13. poisondeathray
    Re: x264 encoding problem
    This is not the problem, even with no sub video doesn't play.
    sneaker
    Ok, that is weird.
    Yes, actually !
    I have just tested your 2 other samples : E not playing, F is OK.
    But what is really weird is why two encodings with same parameters could produce one readable file and not the other one.
  14. Yeah, it seems to be something about the way HandBrake muxes the files. But I don't see anything wrong. If there were a HandBrake error it could at least be reported to the devs and fixed.
  15. G and H are playing well.
    About HandBrake, it is possible, unfortunally if it is the case, encoding successes each time. However, it should be working when remuxed with mkvmerge.
    And your samples work with his muxing.
  16. Originally Posted by umbie View Post
    Apparently not.
    Just FYI: I played SampleA.mkv through SampleF.mkv on my cheap (US$45) Android TV box (with both the native player and Kodi), on a Raspberry Pi 3B (Kodi), and my Android smartphone. They all played properly.
    I also tried playing them on my old LG BD670 Blu-ray player (it can play media files). It didn't like the MKV files with no audio -- it said "audio codec not supported"! So I remuxed with a 10 second AC3 audio clip using MkvToolNix. All the files played properly after that.
    It's probably time for a new player.
  17. G is created by HandBrake 1.1.2. I removed "DisplayUnit" element with MKVToolNix Header Editor.
    H is with HandBrake nightly (unlike 1.1.2 it doesn't write DisplayUnit element in the first place).
  18. I have never go in the header section before.
    I'd try to remove the DisplayUnit elmeent on the original file (the reencoded one, not the source).
    AND IT'S WORKING !!!
    Thank you for very much for your help Sneaker
  19. Good. To make sure that really is the cause you could now try to re-add the element using the Header Editor to test if it stops working.
  20. Just re-added, and don't working. So, we have the cause
    Thank you again Sneaker
  21. Wow cool. Well done @sneaker
