Hello,
I have a particular error regarding editting the x264 configurations in MeGUI. I was wondering what the correct forum would be to post such a thing and get help on the issue?
				Results 1 to 10 of 10
	Update:
 If anyone can help me directly here. This is the log with the particular error. I have been unable to find any other issue like it online.Last edited by DocDomDoe; 22nd Nov 2018 at 23:27.
	This looks like a configuration error, what are you trying to do? What settings are you using?
 Configure your settings, save it with a name then export it with CTRL + E.
	None the less, I have uploaded the default #264 *Scratchpad* preset in which I am getting the error from.
	It's outside the allowed range for CRF. (No idea how it got that way in the first place ... )Code:<VideoEncodingType>quality</VideoEncodingType> [...] <QuantizerCRF>700</QuantizerCRF>
 Simply delete the xml file. MeGUI should create a new one with the standard values.
	Do you mind explaining how I could locate this particular XML, I am unfamiliar.
 *EDIT never mind. I managed to find it, I will look into trying your method.
 Ok, I deleted it. MeGUI however has not created a new x264 *Scratchpad* preset. Even when reinstalling the package.
	*Update
 Ok, since the file would not automatically return. I attempted to manually adjust the value to a "safer" value.
 MeGUI does not recognize the file on opening and searching the listing of encoders. When I close MeGUI, it also deletes the file.
 *Final Update
 Ok, so I deleted my MeGUI folder and reinstalled it. Now I can access #264 *Scratchpad* If others ever have this problem with #264 *scratchpad* config error:
 1. Locate the #264 preset, delete the xml file.
 2. If it MeGUI does not function after that point. Reinstall MeGUI.Last edited by DocDomDoe; 22nd Nov 2018 at 23:28.
	If you delete the x264 scratchpad xml file, you should be able to open the x264 configuration, change any setting, click okay, and MeGUI will create a new one. If you have other x264 presets and you select one of those before opening the x264 configuration, you'd do exactly the same thing, but when you click okay, MeGUI will ask if you want to update the preset or save the changes to scratchpad. It'll create a new scratchpad xml file for the latter.
	I mean, it's not actually important to have the xml file. The scratchpad will work anyway. The end goal is to encode h.264, not xml files.
  MeGUI errorBy Hyemi in forum Video ConversionReplies: 3Last Post: 29th Oct 2017, 00:07
  MeGui GOP errorBy yukukuhi in forum Video ConversionReplies: 7Last Post: 3rd Jul 2016, 12:30
  MeGUI New Error MesssageBy yaston in forum Video ConversionReplies: 7Last Post: 15th Sep 2015, 08:40
  MeGUI Value errorBy Chriscoder in forum Newbie / General discussionsReplies: 2Last Post: 13th Jan 2015, 16:01
  Megui error??By vl4d in forum Newbie / General discussionsReplies: 8Last Post: 25th Dec 2014, 18:04
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
