I have the latest version of DVD Shrink, Nero 2018, and, AnyDVD 8.1.7.1 (Beta.)
I open a disc in AnyDvd, but I can't get that opened disc to then open in DVD Shrink, so I can then export it to Nero. AnyDVD and Nero were installed after I downloaded and installed DVD Shrink. Should I delete all three, reinstall them with DVD Shrink being last to be reinstalled? Or, what is causing this problem. Thanks.
Results 1 to 16 of 16
October;
Until I seem similar topics, after I posted this thread, I didn't know you could "rip" a disc to a file on your hard drive. I even had to Google to find out how to do that. So, soon, when I have a disc I want to "make a back up of" I'll be trying that method-after I uninstall both Nero, and, DVD Shrink, reinstalling first Nero then DVD Shrink.
Thanks for the advice. -
I've tried "ripping" a disc with AnyDVD to my Hard Drive. It appears that it can't copy an IFO file, and, any resulting file can't be read by ShrinkDVD. Once the disc is read by AnyDVD, I'm right clicking on the tray icon, and, selecting "copy to hard drive. In ShrinkDVD I'm selecting open file. Is this the correct procedure? If not, what is? And, if it is, why can AnyDVD copy that ifo file?
An additional problem, NeroRecode "failed to import the DVD structure" I'm guessing that it can't detect a disc in my ROM drive, or, it's not recognizing that I have a ROM drive.
Help with both of these issues will be greatly appreciated.Last edited by agent222; 20th Nov 2018 at 10:54.
What movie are you trying to copy ??
And are you using the free version or
The paid version?? Watch this YouTube tutorial - https://youtu.be/EbIZObfoQXU -
I've had better luck with Passkey and DVDShrink.
https://www.videohelp.com/software/DVDFab-Passkey -
DVDShrink will not open some dvd's. With Anydvd copy dvd to folders, not iso. (on computer). Then with dvdshrink, open folders, walla!
(this allus works for me)
edit: occaisionally I need to use "Fixvts" & then anydvd.
https://www.videohelp.com/software/FixVTSYes, no, maybe, I don't know, Can you repeat the question? -
Cornemuse; What I have been trying is letting AnyDVD scan the disc, then right clicking on the tray icon, selecting the "copy to hard disc" option. The problem, as I have tried to explain, during the copy process I get an error message that shows a red 'x' in the upper left hand corner, and, appears to mention an nfo file.
The resulting file won't open in DVD.
To top it off, the disc-which, as far as I can determine, has had the copy protection removed, doesn't work in NeroRecode, getting the message " failed to import the DVD structure.
Would "Fixvts" solve any of this? -
It happens 'rarely' that I run across a dvd that I cannot rip. Maybe this is one of them.
Cornemuse; you just maybe right for this movie, or, this particular disc of this movie. fixvts has a problem with it, as does DVD Fab Passkey. AnyDVD seems able to open it. But initially has a list of problems, including missmatch of disc and played regions, and, that the disc maybe dirty. But using earlier versions of AnyDVD, and, Recode, to copy Solo, I don't recall seeing that list of possible errors from AnyDVD. Both were released by Disney imprints this year.
Cornemuse;
Tried a different movie to try to "rip". (Incredibles 2) Gently cleaned disc before hand. AnyDVD seemed to open it, but when I tried to create a file from it, it goes through a number of title sets, then starts to copy, stops after less than 10% DVDFab Passkey seems to try and open it, runs for over a minute, but never indicates if it opens it. Even if AnyDVD has opened the disc, NeroRecode either isn't recognizing my CD R/w DVD R drive, or, doesn't recognize that there is a disc in that drive. This is the third Disney imprint movie I've tried to rip. Either Disney has improved it's encryption since Solo, I have faulty software, or, there's something wrong with my computer. Both my DVD drives aren't showing under this PC, although both AnyDVD, and DVDFAb Passkey seem to know my CD RW/DVD W drive is there there when I have a disc in it. And I can usually write to the DVD RW drive from Nero.
DVDShrink + AnyDVD issue with 'All DVD's'
By cornemuse in forum DVD RippingReplies: 27Last Post: 19th Sep 2017, 09:43 -
Philips DVP 5990/37 tray won't open with disc inside--won't play
By Ealdric-1379 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 27th Nov 2016, 17:27 -
Blu-Ray ISO, nothing will open it on my computer, burned disc either
By Guphanti in forum Authoring (Blu-ray)Replies: 34Last Post: 13th Jan 2016, 13:58 -
AnyDVD and AnyDVD HD 7.5.9.0 (Final) not able to work with Interstaller.
By durl in forum Blu-ray RippingReplies: 4Last Post: 7th May 2015, 05:22 -
I used to use AnyDVD with Shrink. What is good now?
By JoeLansing in forum DVD RippingReplies: 5Last Post: 30th Nov 2013, 12:23
