Results 1 to 10 of 10
    Nov 2018
    Have a 30 second 4K HDR MKV clip. I have tried every editor (OS X) I can find and I have even paid for 2. (Easefab and Wondershare). Have also tried every setting possible.
    Trying to get it to 4K MP4 or MOV.
    The video has rich HDR color. When it enters those video editing programs for conversion, the rich color becomes washed out/dull/faded. SDR 4K UHD clips come out OK.
    Is it impossible to convert and retain HDR or am I missing something?
    Any help is greatly appreciated.
    Mar 2011
    Nova Scotia, Canada
    The input may have 10 bit color and the codec/profile/encoder you're using doesn't support this or you haven't enabled it. Pleas post mediainfo output for input and output files.
    Nov 2018
    Here you go. How would I enable 10-bit in the converters? (not specific but a general idea. Can't find it..)
    Mar 2011
    Nova Scotia, Canada
    That info isn't there in that mediainfo mode, switch to text mode and post the text.
    Nov 2018
    General
    Unique ID : 147729495698323614459186750213857271540 (0x6F23AA7B455131BD89C0A88405BCDEF4)
    Complete name : /Users/JDreplace/Desktop/HDR Sample.mkv
    Format : Matroska
    Format version : Version 4
    File size : 40.9 MiB
    Duration : 1 min 14 s
    Overall bit rate : 4 576 kb/s
    Encoded date : UTC 2018-08-07 14:04:28
    Writing application : mkvmerge v24.0.0 ('Beyond The Pale') 64-bit
    Writing library : libebml v1.3.6 + libmatroska v1.4.9
    IsTruncated : Yes
    Video
    Format : HEVC
    Format/Info : High Efficiency Video Coding
    Commercial name : HDR10
    Format profile : Main 10@L5.1@High
    Codec ID : V_MPEGH/ISO/HEVC
    Width : 3 840 pixels
    Height : 2 076 pixels
    Display aspect ratio : 1.85:1
    Frame rate mode : Constant
    Frame rate : 23.976 (24000/1001) FPS
    Color space : YUV
    Chroma subsampling : 4:2:0 (Type 2)
    Bit depth : 10 bits
    Writing library : x265 2.8+10-703eade86b53:[Windows][MSVC 1914][64 bit] 10bit
    Encoding settings : cpuid=1111039 / frame-threads=6 / numa-pools=36 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x2076 / interlace=0 / total-frames=205611 / level-idc=51 / high-tier=1 / uhd-bd=0 / ref=4 / no-allow-non-conformance / repeat-headers / annexb / aud / hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=1 / keyint=24 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=25 / lookahead-slices=4 / scenecut=40 / radl=0 / no-intra-refresh / ctu=64 / min-cu-size=8 / rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=3 / limit-refs=3 / limit-modes / me=3 / subme=3 / merange=57 / temporal-mvp / weightp / no-weightb / no-analyze-src-pics / deblock=-3:-3 / no-sao / no-sao-non-deblock / rd=4 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=1.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=17.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=160000 / vbv-bufsize=160000 / vbv-init=0.9 / crf-max=0.0 / crf-min=0.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=1 / chromaloc-top=2 / chromaloc-bottom=2 / display-window=0 / master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP (15635,16450)L(10000000,1) / max-cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / hdr / hdr-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=5 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-mv-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei
    Default : Yes
    Forced : No
    Color range : Limited
    Color primaries : BT.2020
    Transfer characteristics : PQ
    Matrix coefficients : BT.2020 non-constant
    Mastering display color primaries : Display P3
    Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
    Audio #1
    Format : MLP FBA 16-ch
    Format/Info : Meridian Lossless Packing FBA with 16-channel presentation
    Commercial name : Dolby TrueHD with Dolby Atmos
    Codec ID : A_TRUEHD
    Bit rate mode : Variable
    Maximum bit rate : 7 056 kb/s
    Channel(s) : 8 channels
    Channel layout : L R C LFE Ls Rs Lb Rb
    Sampling rate : 48.0 kHz
    Frame rate : 1 200.000 FPS (40 SPF)
    Compression mode : Lossless
    Language : English
    Default : Yes
    Forced : No
    Number of dynamic objects : 13
    Bed channel count : 1 channel
    Bed channel configuration : LFE
    Audio #2
    Format : AC-3
    Format/Info : Audio Coding 3
    Commercial name : Dolby Digital
    Codec ID : A_AC3
    Bit rate mode : Constant
    Bit rate : 640 kb/s
    Channel(s) : 6 channels
    Frame rate : 31.250 FPS (1536 SPF)
    Bit depth : 16 bits
    Compression mode : Lossy
    Delay relative to video : 6 ms
    Stream size : 5.72 MiB (14%)
    Language : English
    Service kind : Complete Main
    Default : No
    Forced : No
    Text #1
    Format : PGS
    Muxing mode : zlib
    Codec ID : S_HDMV/PGS
    Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
    Language : English
    Default : No
    Forced : No
    Text #2
    Format : PGS
    Muxing mode : zlib
    Title : English Forced
    Language : English
    Default : Yes
    Forced : No
    Text #3
    Format : PGS
    Muxing mode : zlib
    Language : French
    Default : No
    Forced : No
    Text #4
    Format : PGS
    Muxing mode : zlib
    Language : French
    Default : No
    Forced : No
    Text #5
    Format : PGS
    Muxing mode : zlib
    Language : Spanish
    Default : No
    Forced : No
    Text #6
    Format : PGS
    Muxing mode : zlib
    Language : Spanish
    Default : No
    Forced : No
    Text #7
    Format : PGS
    Muxing mode : zlib
    Language : Japanese
    Default : No
    Forced : No
    Text #8
    Format : PGS
    Muxing mode : zlib
    Language : Japanese
    Default : No
    Forced : No
    Text #9
    Format : PGS
    Muxing mode : zlib
    Language : Chinese
    Default : No
    Forced : No
    Text #10
    Format : PGS
    Muxing mode : zlib
    Language : Chinese
    Default : No
    Forced : No
    Text #11
    Format : PGS
    Muxing mode : zlib
    Language : Korean
    Default : No
    Forced : No
    Menu
    00:00:00.000 : en:00:00:00.000
    Nov 2018
    I have ruled something out. The SDR clips are also 10-bit so its not the bits. Its the color, right?
  7. Originally Posted by JDLangton
    https://forum.doom9.org/showthread.php?t=175125
    upps
    I'm sorry It is not what you want.
    regards
    責任者-MDX
    Nov 2018
    No idea what youre saying. Way out of my league
    Nov 2018
    Think i figured it out. No converters support H265
  10. HDR 4k content needs to be interpreted from bt.2020 to bt.709 using tone-mapping method. It has to be part of encoder if dealing with HDR. Or you do it before you load video into your encoder.
    Encoder like Hybrid for Mac should be ready for this, you might try that. If it cannot make MOV container directly, you can get MP4 or MKV and then using some multiplexer to get MOV.
